Retrieve cluster network security certificate configuration for a node
Retrieves the certificate configuration for cluster network security on a specified node to verify or audit its security settings and ensure secure communication within your ONTAP environment.
HTTP method and endpoint
GET /security/cluster-network/certificates/{node.uuid}
Introduced in
ONTAP 9.18
Usage notes
Retrieves the certificate configuration for cluster network security for a given node.
Related ONTAP commands
'security cluster-network certificate show'
node.uuid |
string |
path |
True |
Node UUID. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
certificate |
Security certificate object reference |
node |
"href": "/api/resourcelink"
"certificate": {
"name": "string",
"node": {
"name": "node1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
security_certificate_reference
_links |
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
node_reference
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
