Retrieve the cluster network security configuration
GET /security/cluster-network
Introduced In: 9.18
Retrieves the cluster network security configuration.
Related ONTAP commands
'security cluster-network show'
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
enabled |
boolean |
Indicates whether cluster network security is enabled. |
mode |
string |
The cluster network security mode. |
status |
string |
The status of the cluster network security configuration. |
"href": "/api/resourcelink"
"mode": "string",
"status": "ENABLING | DISABLING | READY"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
