REST API reference
Retrieve the cluster network security configuration
Retrieves the cluster network security configuration to review the current security settings and ensure that your cluster's network communications are protected according to your organization's policies.
HTTP method and endpoint
GET /security/cluster-network
Introduced in
ONTAP 9.18
  • 'security cluster-network show'
status
string
query
False
Filter by status
  • Introduced in: 9.19
ipsec_status
string
query
False
Filter by ipsec_status
mode
string
query
False
Filter by mode
enabled
boolean
query
False
Filter by enabled
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
enabled
boolean
Indicates whether cluster network security is enabled.
ipsec_status
string
The IPsec status of the cluster network security configuration.
mode
string
The cluster network security mode.
  • tls: Protect cluster traffic using TLS.
  • tls_ipsec: CSM traffic uses TLS, all other cluster network traffic uses IPsec.
status
string
The certificate and TLS status of the cluster network security configuration.
      "href": "/api/resourcelink"
  "ipsec_status": "ENABLING | DISABLING | READY",
  "mode": "string",
  "status": "ENABLING | DISABLING | READY"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
