REST API reference
Retrieve all group entries
GET /security/groups
Introduced In: 9.16
Retrieves all group entries.
  • security login group show
type
string
query
False
Filter by type
id
integer
query
False
Filter by id
name
string
query
False
Filter by name
  • maxLength: 64
  • minLength: 1
scope
string
query
False
Filter by scope
uuid
string
query
False
Filter by uuid
comment
string
query
False
Filter by comment
owner.name
string
query
False
Filter by owner.name
owner.uuid
string
query
False
Filter by owner.uuid
create_time
string
query
False
Filter by create_time
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of records.
records
array[security_group]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "comment": "Azure Group",
      "create_time": "string",
      "id": 0,
      "name": "AzureGroup1",
      "owner": {
        "name": "svm1",
      "scope": "string",
      "type": "entra",
      "uuid": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
self
owner
Group owner. Used to identify a cluster or an SVM.
_links
_links
name
string
uuid
string
security_group
_links
self_link
comment
string
Any comment regarding this group entry.
create_time
string
Date and time indicating when this group entry was created.
id
integer
Group ID which is unique per group across the system. It is a read-only field and it automatically assigns the next available unique number.
name
string
Group name.
owner
owner
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
type
string
Group type.
uuid
string
Group UUID from external Active Directory.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
