Retrieve the HA network security configuration
GET /security/ha-network
Introduced In: 9.18
Retrieves the HA network security configuration.
Related ONTAP commands
'security ha-network show'
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
enabled |
boolean |
Indicates if HA network security is enabled. |
node.name |
Node name |
"href": "/api/resourcelink"
"node.name": {
"name": "node1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
_links
self |
node.name
Node name
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
