REST API reference
Retrieve the HA network security configuration
Retrieves the HA network security configuration to review current security settings for high availability in your network.
HTTP method and endpoint
GET /security/ha-network
Introduced in
ONTAP 9.18
  • 'security ha-network show'
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
enabled
boolean
Indicates if HA network security is enabled.
node.name
node.name
Node name
      "href": "/api/resourcelink"
  "node.name": {
    "name": "node1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
self
node.name
Node name
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
