REST API reference
Retrieve the login banner and messages of the day
GET /security/login/messages
Introduced In: 9.6
Retrieves the login banner and messages of the day (MOTD) configured in the cluster and in specific SVMs.
banner
string
query
False
Filter by banner
  • maxLength: 2048
  • minLength: 0
uuid
string
query
False
Filter by uuid
scope
string
query
False
Filter by scope
message
string
query
False
Filter by message
  • maxLength: 2048
  • minLength: 0
show_cluster_message
boolean
query
False
Filter by show_cluster_message
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[login_messages]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "banner": "string",
      "message": "string",
      "scope": "string",
      "svm": {
        "name": "svm1",
      "uuid": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
_links
_links
name
string
uuid
string
login_messages
The login banner and message of the day (MOTD) configuration.
_links
_links
banner
string
The login banner text. This message is displayed during SSH and console device login just before the password prompt displays. When configured, a cluster-level login banner is used for every incoming connection. Each data SVM can override the cluster-level banner to instead display when you log into the SVM. To restore the default setting for a data SVM, set the banner to an empty string. New lines are supplied as either LF or CRLF but are always returned as LF. Optional in the PATCH body.
message
string
The message of the day (MOTD). This message appears just before the clustershell prompt after a successful login. When configured, the cluster message displays first. If you log in as a data SVM administrator, the SVM message is then printed. The cluster-level MOTD can be disabled for a given data SVM using the "show_cluster_message" property. New lines are supplied as either LF or CRLF but are always returned as LF. Optional in the PATCH body.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
boolean
Specifies whether to show a cluster-level message before the SVM message when logging in as an SVM administrator. This setting can only be modified by cluster administrators. Optional in the PATCH body.
svm
svm
uuid
string
The unique identifier (ID) of the login messages configuration.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
