Retrieve the login banner and messages of the day
Accesses the login banner and messages of the day (MOTD) configured in the cluster and specific SVMs. This is useful for reviewing or auditing current login messages.
HTTP method and endpoint
GET /security/login/messages
Introduced in
ONTAP 9.6
Usage notes
Retrieves the login banner and messages of the day (MOTD) configured in the cluster and in specific SVMs.
uuid |
string |
query |
False |
Filter by uuid |
show_cluster_message |
boolean |
query |
False |
Filter by show_cluster_message |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
message |
string |
query |
False |
Filter by message
scope |
string |
query |
False |
Filter by scope |
banner |
string |
query |
False |
Filter by banner
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[login_messages] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"banner": "string",
"message": "string",
"scope": "string",
"svm": {
"name": "svm1",
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
uuid |
string |
login_messages
The login banner and message of the day (MOTD) configuration.
_links |
banner |
string |
The login banner text. This message is displayed during SSH and console device login just before the password prompt displays. When configured, a cluster-level login banner is used for every incoming connection. Each data SVM can override the cluster-level banner to instead display when you log into the SVM. To restore the default setting for a data SVM, set the banner to an empty string. New lines are supplied as either LF or CRLF but are always returned as LF. Optional in the PATCH body. |
message |
string |
The message of the day (MOTD). This message appears just before the clustershell prompt after a successful login. When configured, the cluster message displays first. If you log in as a data SVM administrator, the SVM message is then printed. The cluster-level MOTD can be disabled for a given data SVM using the "show_cluster_message" property. New lines are supplied as either LF or CRLF but are always returned as LF. Optional in the PATCH body. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
boolean |
Specifies whether to show a cluster-level message before the SVM message when logging in as an SVM administrator. This setting can only be modified by cluster administrators. Optional in the PATCH body. |
svm |
uuid |
string |
The unique identifier (ID) of the login messages configuration. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
