REST API reference
Retrieve the origin of a FlexCache in the cluster
GET /storage/flexcache/origins
Introduced In: 9.6
Retrieves origin of FlexCache in the cluster.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • flexcaches.ip_address - IP address of FlexCache.
  • flexcaches.size - Physical size of FlexCache.
  • flexcaches.guarantee.type - Space guarantee style of FlexCache.
  • flexcaches.state - State of FlexCache.
  • volume flexcache origin show-caches
uuid
string
query
False
Filter by uuid
block_level_invalidation
boolean
query
False
Filter by block_level_invalidation
  • Introduced in: 9.9
global_file_locking_enabled
boolean
query
False
Filter by global_file_locking_enabled
name
string
query
False
Filter by name
  • maxLength: 203
  • minLength: 1
flexcaches.create_time
string
query
False
Filter by flexcaches.create_time
string
query
False
Filter by flexcaches.ip_address
flexcaches.state
string
query
False
Filter by flexcaches.state
flexcaches.volume.name
string
query
False
Filter by flexcaches.volume.name
flexcaches.volume.uuid
string
query
False
Filter by flexcaches.volume.uuid
flexcaches.svm.name
string
query
False
Filter by flexcaches.svm.name
flexcaches.svm.uuid
string
query
False
Filter by flexcaches.svm.uuid
flexcaches.size
integer
query
False
Filter by flexcaches.size
flexcaches.cluster.name
string
query
False
Filter by flexcaches.cluster.name
flexcaches.cluster.uuid
string
query
False
Filter by flexcaches.cluster.uuid
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
return_records
boolean
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[flexcache_origin]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "flexcaches": [
          "cluster": {
            "name": "cluster1",
          "create_time": "2018-06-04 19:00:00 +0000",
          "ip_address": "10.10.10.7",
          "size": 0,
          "state": "string",
          "svm": {
            "name": "svm1",
          "volume": {
            "name": "volume1",
      "name": "vol1, vol_2",
      "svm": {
        "name": "svm1",
      "uuid": "1cd8a442-86d1-11e0-ae1c-123478563512"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
cluster
_links
_links
name
string
uuid
string
svm
_links
_links
name
string
uuid
string
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
flexcache_relationship
cluster
cluster
create_time
string
Creation time of the relationship.
ip_address
string
Cluster management IP of the remote cluster.
size
integer
Size of the remote volume.
state
string
Volume state
svm
svm
volume
volume
svm
Origin volume SVM
_links
_links
name
string
uuid
string
flexcache_origin
Defines the origin endpoint of FlexCache.
_links
_links
boolean
Block level invalidation enables the FlexCache volume to retain blocks that are not changed at the FlexCache volume without having to evict them. This means that the FlexCache volume does not have to again incur the computational cost of fetching blocks over the WAN from the FlexCache volume origin on the next client access. Block level invalidation is a property of the origin volume. Without block level invalidation, any write at the origin volume would evict the whole file at the FlexCache volume, since by default, origin volume does a file level invalidation.
flexcaches
array[flexcache_relationship]
boolean
Specifies whether a global file locking option is enabled for an origin volume of a FlexCache volume.
name
string
Origin volume name
svm
svm
Origin volume SVM
uuid
string
Origin volume UUID. Unique identifier for origin of FlexCache.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
