Retrieve the origin of a FlexCache volume in the cluster
Retrieves the origin information of a FlexCache volume within the cluster. Use this endpoint to access specific details about the FlexCache's configuration and status, which may be necessary for monitoring or managing storage resources.
HTTP method and endpoint
GET /storage/flexcache/origins
Introduced in
ONTAP 9.6
Usage notes
Retrieves origin of FlexCache in the cluster.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
flexcaches.ip_address- IP address of FlexCache. -
flexcaches.size- Physical size of FlexCache. -
flexcaches.guarantee.type- Space guarantee style of FlexCache. -
flexcaches.state- State of FlexCache.
Related ONTAP commands
volume flexcache origin show-caches
Learn more
block_level_invalidation |
boolean |
query |
False |
Filter by block_level_invalidation
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
name |
string |
query |
False |
Filter by name |
global_file_locking_enabled |
boolean |
query |
False |
Filter by global_file_locking_enabled
flexcaches.size |
integer |
query |
False |
Filter by flexcaches.size |
flexcaches.create_time |
string |
query |
False |
Filter by flexcaches.create_time |
flexcaches.volume.name |
string |
query |
False |
Filter by flexcaches.volume.name |
flexcaches.volume.uuid |
string |
query |
False |
Filter by flexcaches.volume.uuid |
flexcaches.svm.uuid |
string |
query |
False |
Filter by flexcaches.svm.uuid |
flexcaches.svm.name |
string |
query |
False |
Filter by flexcaches.svm.name |
flexcaches.state |
string |
query |
False |
Filter by flexcaches.state |
flexcaches.cluster.name |
string |
query |
False |
Filter by flexcaches.cluster.name |
flexcaches.cluster.uuid |
string |
query |
False |
Filter by flexcaches.cluster.uuid |
flexcaches.ip_address |
string |
query |
False |
Filter by flexcaches.ip_address |
uuid |
string |
query |
False |
Filter by uuid |
return_timeout |
integer |
query |
False |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
return_records |
boolean |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[flexcache_origin] |
"next": {
"href": "/api/resourcelink"
"records": [
"flexcaches": [
"cluster": {
"name": "cluster1",
"create_time": "2018-06-04T19:00:00Z",
"ip_address": "10.10.10.7",
"size": 0,
"state": "string",
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
"name": "vol1, vol_2",
"svm": {
"name": "svm1",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563512"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
cluster
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
flexcache_relationship
cluster |
create_time |
string |
Creation time of the relationship. |
ip_address |
string |
Cluster managerment IP of the remote cluster. |
size |
integer |
Size of the remote volume. |
state |
string |
Volume state |
svm |
volume |
svm
Origin volume SVM
_links |
name |
string |
uuid |
string |
flexcache_origin
Defines the origin endpoint of FlexCache.
_links |
boolean |
Block level invalidation enables the FlexCache volume to retain blocks that are not changed at the FlexCache volume without having to evict them. This means that the FlexCache volume does not have to again incur the cost of fetching blocks over the WAN from the FlexCache volume origin on the next client access. Block level invalidation is a property of the origin volume. Without block level invalidation, any write at the origin volume would evict the whole file at the FlexCache volume, since by default, origin volume does a file level invalidation. |
flexcaches |
array[flexcache_relationship] |
boolean |
Specifies whether a global file locking option is enabled for an origin volume of a FlexCache volume. |
name |
string |
Origin volume name |
svm |
Origin volume SVM |
uuid |
string |
Origin volume UUID. Unique identifier for origin of FlexCache. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
