REST API reference
Create an NVMe subsystem
POST /protocols/nvme/subsystems
Introduced In: 9.6
Creates an NVMe subsystem.
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the NVMe subsystem.
  • name - Name for NVMe subsystem. Once created, an NVMe subsystem cannot be renamed.
  • os_type - Operating system of the NVMe subsystem's hosts.
  • vserver nvme subsystem create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
comment
string
A configurable comment for the NVMe subsystem. Optional in POST and PATCH.
delete_on_unmap
boolean
An option that causes the subsystem to be deleted when the last subsystem map associated with it is deleted. Optional in POST and PATCH. This property defaults to false when the subsystem is created.
hosts
array[hosts]
The NVMe hosts configured for access to the NVMe subsystem. Optional in POST.
io_queue
io_queue
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller.
name
string
The name of the NVMe subsystem. Once created, an NVMe subsystem cannot be renamed. Required in POST.
os_type
string
The host operating system of the NVMe subsystem's hosts. Required in POST.
replication
replication
Properties related to subsystem replication.
serial_number
string
The serial number of the NVMe subsystem.
subsystem_maps
array[subsystem_maps]
The NVMe namespaces mapped to the NVMe subsystem.
There is an added computational cost to retrieving property values for subsystem_maps. They are not populated for a GET request unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
svm
svm
target_nqn
string
The NVMe qualified name (NQN) used to identify the NVMe storage target.
uuid
string
The unique identifier of the NVMe subsystem.
vendor_uuids
array[string]
Vendor-specific identifiers (UUIDs) optionally assigned to an NVMe subsystem when the subsystem is created. The identifiers are used to enable vendor-specific NVMe protocol features. The identifiers are provided by a host application vendor and shared with NetApp prior to a joint product release. Creating an NVMe subsystem with an unknown or non-specific identifier will have no effect on the NVMe subsystem. Refer to the ONTAP SAN Administration Guide for a list of the supported vendor-specific identifiers. After a subsystem is created, the vendor-specific identifiers cannot be changed or removed. Optional in POST.
  • Introduced in: 9.9
  • readCreate: 1
Example request
  "comment": "string",
  "hosts": [
      "dh_hmac_chap": {
        "controller_secret_key": "DHHC-1:00:ia6zGodOr4SEG0Zzaw398rpY0wqipUWj4jWjUh4HWUz6aQ2n:",
        "group_size": "string",
        "hash_function": "string",
        "host_secret_key": "DHHC-1:00:ia6zGodOr4SEG0Zzaw398rpY0wqipUWj4jWjUh4HWUz6aQ2n:",
        "mode": "bidirectional"
      "nqn": "nqn.1992-01.example.com:string",
      "priority": "string",
      "proximity": {
        "peer_svms": [
            "name": "peer1",
            "uuid": "4204cf77-4c82-9bdb-5644-b5a841c097a9"
      "tls": {
        "configured_psk": "NVMeTLSkey-1:01:VRLbtnN9AQb2WXW3c9+wEf/DRLz0QuLdbYvEhwtdWwNf9LrZ:",
        "key_type": "configured"
  "io_queue": {
    "default": {
      "count": 4,
      "depth": 16
  "name": "subsystem1",
  "os_type": "string",
  "replication": {
    "error": {
      "subsystem": {
    "peer_subsystem": {
      "uuid": "1cd8a443-86d2-11e0-ae1c-123478563412"
    "peer_svm": {
      "name": "peer1",
    "state": "string"
  "serial_number": "wCVsgFMiuMhVAAAAAAAB",
  "subsystem_maps": [
      "anagrpid": "00103050h",
      "namespace": {
        "name": "/vol/vol1/namespace1",
      "nsid": "00000001h"
  "svm": {
    "name": "svm1",
  "target_nqn": "nqn.1992-01.example.com:string",
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "vendor_uuids": [
    "1447f0f4-42e5-0dfc-871a-dc9b3f92d8f8"
Status: 201, Created
num_records
integer
The number of records in the response.
records
array[nvme_subsystem]
  "num_records": 1,
  "records": [
      "hosts": [
          "dh_hmac_chap": {
          "proximity": {
            "peer_svms": [
                "name": "peer1",
          "tls": {
      "io_queue": {
        "default": {
          "count": 4,
          "depth": 16
      "replication": {
        "error": {
          "subsystem": {
        "peer_subsystem": {
        "peer_svm": {
          "name": "peer1",
        "state": "string"
      "subsystem_maps": [
          "namespace": {
          "nsid": "00000001h"
      "svm": {
        "name": "svm1",
      "vendor_uuids": [
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
2621462
The supplied SVM does not exist.
2621706
The specified svm.uuid and svm.name do not refer to the same SVM.
2621707
The svm.uuid or svm.name must be provided.
72089635
Setting vendor-specific UUIDs on NVMe subsystems is not supported until the effective cluster version is 9.9 or later.
72089636
Creating NVMe subsystems with os_type AIX is not supported until the effective cluster version is 9.13.1 or later.
72089709
The NVMe subsystem name contains an invalid character.
72089711
An invalid vendor-specific UUID was specified.
72089712
A duplicate vendor-specific UUID was specific.
72089713
Too many vendor UUIDs were supplied.
72089716
The DH-HMAC-CHAP secret property is invalid. DH-HMAC-CHAP secrets must be in the format "DHHC-1:0X:<Base 64 encoded key and CRC>:", where X represents 0, 1, or 3 indicating no hash function, SHA-256, and SHA-512 respectively.
72089771
The NQN is invalid. A non-empty qualifier is required after the prefix. An example of a valid NQN is nqn.1992-01.com.example:string.
72089772
The NQN is invalid. Add the prefix 'nqn'. An example of a valid NQN is nqn.1992-01.com.example:string.
72089773
The NQN is invalid. The date field must be formatted yyyy-mm. An example of a valid NQN is nqn.1992-01.com.example:string.
72090003
A host to be added to an NVMe subsystem is missing the "nqn" property.
72090025
The NVMe subsystem already exists for the SVM.
72090029
The NVMe service does not exist.
72090030
A partial success occurred while adding multiple NVMe subsystem hosts to an NVMe subsystem.
72090036
An NVMe subsystem host NQN was duplicated in the input.
72090042
The DH-HMAC-CHAP secret property is required when setting any other NVMe in-band authentication properties for a host.
72090043
An igroup already exists with the requested NVMe subsystem name.
72090151
NVMe/TCP-TLS is not supported for the effective version of the cluster.
72090202
A provided NVMe subsystem host TLS configured PSK is not valid.
72090204
A TLS configured PSK was not provided when adding an NVMe subsystem host with the configured key type.
72090205
An invalid combination for the TLS key type and configured PSK values was provided when adding an NVMe subsystem host. When key type is "none", no configured PSK is allowed. When key type is "configured", a configured PSK is required.
string
dh_hmac_chap
A container for the configuration of NVMe in-band authentication using the DH-HMAC-CHAP protocol for a host.
string
The controller secret for NVMe in-band authentication. The value of this property is used by the NVMe host to authenticate the NVMe controller while establishing a connection. If unset, the controller is not authenticated. When supplied, the property host_secret_key must also be supplied. Optional in POST.
This property is write-only. The mode property can be used to identify if a controller secret has been set for the host, but the controller secret value cannot be read. To change the value, the host must be deleted from the subsystem and re-added.
group_size
string
The Diffie-Hellman group size for NVMe in-band authentication. When property host_secret_key is provided, this property defaults to 2048_bit. When supplied, the property host_secret_key must also be supplied. Optional in POST.
hash_function
string
The hash function for NVMe in-band authentication. When property host_secret_key is provided, this property defaults to sha_256. When supplied, the property host_secret_key must also be supplied. Optional in POST.
host_secret_key
string
The host secret for NVMe in-band authentication. The value of this property is used by the NVMe controller to authenticate the NVMe host while establishing a connection. If unset, no authentication is performed by the host or controller. This property must be supplied if any other NVMe in-band authentication properties are supplied. Optional in POST.
This property is write-only. The mode property can be used to identify if a host secret has been set for the host, but the host secret value cannot be read. To change the value, the host must be deleted from the subsystem and re-added.
mode
string
The expected NVMe in-band authentication mode for the host. This property is an indication of which secrets are configured for the host. When set to:
  • none: The host has neither the host nor controller secret configured, and no authentication is performed.
  • unidirectional: The host has a host secret configured. The controller will authenticate the host.
  • bidirectional: The host has both a host and controller secret configured. The controller will authenticate the host and the host will authenticate the controller.
peer_svms
A reference to an SVM peer relationship.
name
string
The local name of the peer SVM. This name is unique among all local and peer SVMs.
uuid
string
The unique identifier of the SVM peer relationship. This is the UUID of the relationship, not the UUID of the peer SVM itself.
proximity
Properties that define the SVMs to which the host is proximal. This information is used to properly report active optimized and active non-optimized network paths using an NVMe controller. If no configuration has been specified for the host, the sub-object is not present in GET requests.
These properties apply to all instances of the host in the NVMe subsystem in the SVM and its peers.
local_svm
boolean
A boolean that indicates if the host is proximal to the SVM for which it is configured.
peer_svms
array[peer_svms]
An array of remote peer SVMs to which the host is proximal.
tls
A container for the configuration for NVMe/TCP-TLS transport session for the host.
configured_psk
string
A user supplied pre-shared key (PSK) value in PSK Interchange Format. Optional in POST.
The values for property key_type and property configured_psk must logically agree. This property is only allowed when key_type is configured. If configured_psk is supplied and key_type is unset, key_type defaults to configured.
This property is write-only. The key_type property can be used to identify if a configured PSK has been set for the host, but the PSK value cannot be read. To change the value, the host must be deleted from the subsystem and re-added.
key_type
string
The method by which the TLS pre-shared key (PSK) is configured for the host. Optional in POST.
Possible values:
  • none - TLS is not configured for the host connection. No value is allowed for property configured_psk.
  • configured - A user supplied PSK is configured for the NVMe/TCP-TLS transport connection between the host and the NVMe subsystem. A valid value for property configured_psk is required.
This property defaults to none unless a value is supplied for configured_psk in which case it defaults to configured.
hosts
dh_hmac_chap
dh_hmac_chap
nqn
string
priority
string
The host priority setting allocates appropriate NVMe I/O queues (count and depth) for the host to submit I/O commands. Absence of this property in GET implies user configured values of I/O queue count and I/O queue depth are being used.
proximity
proximity
tls
tls
default
Important Support for this field will be removed in a future release. The default I/O queue parameters inherited by NVMe hosts in the NVMe subsystem.
count
integer
The number of host I/O queue pairs.
depth
integer
The host I/O queue depth.
io_queue
default
default
subsystem
An NVMe subsystem maintains configuration state and NVMe namespace access control for a set of NVMe-connected hosts.
local_svm
boolean
Indicates whether the reported subsystem is on the local SVM or the peer SVM. When deleting a replicated subsystem, the local copy is deleted first and then the peer copy is deleted. If the error is encountered between these two operations and only the peer subsystem remains, the peer subsystem is reported and the problem might need to be corrected on the peer cluster.
name
string
uuid
string
code
string
Argument code
message
string
Message argument
summary
A user friendly message describing the error.
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
error
Information about asynchronous errors encountered while replicating this subsystem. Subsystems within a peering relationship are replicated in the same stream, so the error reported here might be related to this subsystem or a prior replicated subsystem that is now blocking the replication of this subsystem. Both the error information and the subsystem encountering the error are reported. If the error is configuration related, it can be corrected on the referenced subsystem. The replication is retried using exponential backoff up to a maximum of one retry every 5 minutes. Every operation on the same stream triggers an immediate retry and restarts the exponential backoff starting with a 1 second delay. If the error is system related, the retries should correct the error when the system enters a healthy state.
subsystem
subsystem
peer_subsystem
uuid
string
The unique identifier of the peer subsystem.
peer_svm
The peered SVM to which the subsystem is replicated. Subsystem are are automatically replicated when mapped to a namespace in a SnapMirror active sync relationship. When a subsystem is mapped to a namespace in an active sync relationship, the subsystem is restricted to only be mapped to namespaces that are members of the same consistency group.
name
string
uuid
string
replication
error
error
peer_subsystem
peer_subsystem
peer_svm
peer_svm
state
string
The state of the replication queue associated with this subsystem. If this subsystem is not in the replication queue, the state is reported as ok. If this subsystem is in the replication queue, but no errors have been encountered, the state is reported as replicating. If this subsystem is in the replication queue and the queue is blocked by an error, the state is reported as error. When in the error state, additional context is provided by the replication.error property.
namespace
An NVMe namespace mapped to the NVMe subsystem.
name
string
The name of the NVMe namespace.
uuid
string
The unique identifier of the NVMe namespace.
subsystem_maps
anagrpid
string
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace.
The format for an ANAGRPIP is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
namespace
namespace
nsid
string
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace.
The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
svm
name
string
uuid
string
nvme_subsystem
An NVMe subsystem maintains configuration state and namespace access control for a set of NVMe-connected hosts.
comment
string
delete_on_unmap
boolean
hosts
array[hosts]
io_queue
io_queue
name
string
os_type
string
replication
replication
serial_number
string
subsystem_maps
svm
svm
target_nqn
string
uuid
string
vendor_uuids
array[string]
  • readCreate: 1
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
