REST API reference
Create the S3 bucket configuration for an SVM
POST /protocols/s3/buckets
Introduced In: 9.8
Creates the S3 bucket configuration of an SVM.
Important notes
  • Each SVM can have one or more bucket configurations.
  • Aggregate lists should be specified explicitly. If not specified, then the bucket is auto-provisioned as a FlexGroup volume.
  • Constituents per aggregate specifies the number of components (or FlexVol volumes) per aggregate. Is specified only when an aggregate list is explicitly defined.
  • An access policy can be created along with a bucket create. If creating an access policy fails, bucket configurations are saved and the access policy can be created using the PATCH endpoint.
  • "qos_policy" can be specified if a bucket needs to be attached to a QoS group policy during creation time.
  • "audit_event_selector" can be specified if a bucket needs to be specify access and permission type for auditing.
  • A CORS configuration can be specified along with bucket creation.
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the bucket configuration.
  • name - Bucket name that is to be created.
  • aggregates - List of aggregates for the FlexGroup volume on which the bucket is hosted on.
  • constituents_per_aggregate - Number of constituents per aggregate.
  • size - Specifying the bucket size is recommended.
  • policy - Specifying a policy enables users to perform operations on buckets; specifying the resource permissions is recommended.
  • qos_policy - A QoS policy for buckets.
  • audit_event_selector - Audit policy for buckets.
  • versioning_state - Versioning state for buckets.
  • type - Type of bucket.
  • nas_path - NAS path to which the bucket corresponds to.
  • use_mirrored_aggregates - Specifies whether mirrored aggregates are selected when provisioning a FlexGroup volume.
  • lifecycle_management - Object store server lifecycle management policy.
  • retention.mode - Object lock mode supported on the bucket.
  • retention.default_period - Specifies the duration of default-retention applicable for objects on the object store bucket.
  • cors - Specifying CORS rules enables the bucket to service the cross-origin requests.
  • snapshot_policy - Snapshot policy for the bucket.
  • is_nas_path_mutable - Specifies whether the NAS bucket mapping with a NAS volume can change according to the changes in the NAS volume junction-path due to volume operations like mount and unmount.
Default property values
  • size - 800MB
  • comment - ""
  • aggregates - No default value.
  • constituents_per_aggregate - 4 , if an aggregates list is specified. Otherwise, no default value.
  • policy.statements.actions - GetObject, PutObject, DeleteObject, ListBucket, ListBucketMultipartUploads, ListMultipartUploadParts, GetObjectTagging, PutObjectTagging, DeleteObjectTagging, GetBucketVersioning, PutBucketVersioning.
  • policy.statements.principals - all S3 users and groups in the SVM or the NAS groups.
  • policy.statements.resources - all objects in the bucket.
  • policy.statements.conditions - list of bucket policy conditions.
  • versioning_state - disabled.
  • use_mirrored_aggregates - true for a MetroCluster configuration and false for a non-MetroCluster configuration.
  • type - S3
  • retention.mode - no_lock
  • vserver object-store-server bucket create
  • vserver object-store-server bucket policy statement create
  • vserver object-store-server bucket lifecycle-management-rule create
  • vserver object-store-server bucket cors-rule create
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
aggregates
array[aggregates]
A list of aggregates for FlexGroup volume constituents where the bucket is hosted. If this option is not specified, the bucket is auto-provisioned as a FlexGroup volume.
allowed
boolean
If this is set to true, an SVM administrator can manage the S3 service. If it is false, only the cluster administrator can manage the service. This field cannot be specified in a POST method.
Audit event selector allows you to specify access and permission types to audit.
comment
string
Can contain any additional information about the bucket being created or modified.
integer
Specifies the number of constituents or FlexVol volumes per aggregate. A FlexGroup volume consisting of all such constituents across all specified aggregates is created. This option is used along with the aggregates option and cannot be used independently.
cors
cors
Cross-origin resource sharing (CORS) specifies an object associated with a bucket. The CORS configuration enables the bucket to service the cross-origin requests. A request might typically come from an origin with a domain that is different to that of the bucket. By configuring a CORS rule, you can define a combination of allowed origins, HTTP headers and methods that a bucket can use to filter out the cross-origin requests that it can service successfully.
encryption
encryption
is_consistent_etag
boolean
Specifies whether the NAS bucket returns a consistent ETag across different S3 requests.
is_nas_path_mutable
boolean
Specifies whether the NAS bucket mapping or association with a NAS volume can change according to the changes in the NAS volume junction-path due to volume operations like mount and unmount and therefore the NAS bucket will have access to any path in a NAS volume that matches the specified nas-path. Or is immutable and therefore the NAS bucket will always have access to the same nas-path that was specified during bucket creation even if the volume junction-path has undergone changes after the bucket creation.
Lifecycle management is implemented as an object associated with a bucket. It defines rules to be applied against objects within a bucket. These rules are applied in the background and can delete objects.
logical_used_size
integer
Specifies the bucket logical used size up to this point. This field cannot be specified using a POST or PATCH method.
name
string
Specifies the name of the bucket. Bucket name is a string that can only contain the following combination of ASCII-range alphanumeric characters 0-9, a-z, ".", and "-".
nas_path
string
Specifies the NAS path to which the nas bucket corresponds to.
policy
policy
A policy is an object associated with a bucket. It defines resource (bucket, folder, or object) permissions. These policies get evaluated when an S3 user makes a request by executing a specific command. The user must be part of the principal (user or group) specified in the policy. Permissions in the policies determine whether the request is allowed or denied.
protection_status
protection_status
Specifies attributes of bucket protection.
qos_policy
qos_policy
Specifies "qos_policy.max_throughput_iops" and/or "qos_policy.max_throughput_mbps" or "qos_policy.min_throughput_iops" and/or "qos_policy.min_throughput_mbps". Specifying "min_throughput_iops" or "min_throughput_mbps" is only supported on volumes hosted on a node that is flash optimized. A pre-created QoS policy can also be used by specifying "qos_policy.name" or "qos_policy.uuid" properties. Setting or assigning a QoS policy to a bucket is not supported if its containing volume or SVM already has a QoS policy attached.
retention
retention
Specifies the retention mode and default retention period configured on the bucket.
role
string
Specifies the role of the bucket. This field cannot be specified using a POST method.
size
integer
Specifies the bucket size in bytes; ranges from 100GB to 60PB.
snapshot_policy
snapshot_policy
Specifies the bucket snapshot policy.
snapshot_restore
snapshot_restore
Specifies information regarding a snapshot restore operation on the bucket
storage_service_level
string
Specifies the storage service level of the FlexGroup volume on which the bucket should be created. Valid values are "value", "performance" or "extreme".
svm
svm
type
string
Specifies the bucket type. Valid values are "s3"and "nas".
boolean
Specifies whether mirrored aggregates are selected when provisioning a FlexGroup. Only mirrored aggregates are used if this parameter is set to "true" and only unmirrored aggregates are used if this parameter is set to "false". The default value is "true" for a MetroCluster configuration and is "false" for a non-MetroCluster configuration.
uuid
string
Specifies the unique identifier of the bucket.
versioning_state
string
Specifies the versioning state of the bucket. Valid values are "disabled", "enabled" or "suspended". Note that the versioning state cannot be modified to 'disabled' from any other state.
volume
volume
Specifies the FlexGroup volume name and UUID where the bucket is hosted.
Example request
  "aggregates": [
      "name": "aggr1",
  "audit_event_selector": {
    "access": "string",
    "permission": "string"
  "comment": "S3 bucket.",
  "constituents_per_aggregate": 4,
  "cors": {
    "rules": [
        "allowed_headers": [
          "x-amz-request-id"
        "allowed_methods": [
          "PUT",
          "DELETE"
        "allowed_origins": [
          "http://www.example.com"
        "expose_headers": [
          "x-amz-date"
        "id": "string",
        "max_age_seconds": 1024
  "lifecycle_management": {
    "rules": [
        "bucket_name": "bucket1",
        "expiration": {
          "object_age_days": 100,
          "object_expiry_date": "2039-09-23 00:00:00 +0000"
        "name": "string",
        "object_filter": {
          "prefix": "/logs",
          "size_greater_than": 10240,
          "size_less_than": 10485760,
          "tags": [
            "project1=projA",
            "project2=projB"
        "svm": {
          "name": "svm1",
        "uuid": "414b29a1-3b26-11e9-bd58-0050568ea055"
  "logical_used_size": 0,
  "name": "bucket1",
  "nas_path": "/",
  "policy": {
    "statements": [
        "actions": [
          "GetObject",
          "PutObject",
          "DeleteObject",
          "ListBucket"
        "conditions": [
            "delimiters": [
            "max_keys": [
              1000
            "operator": "ip_address",
            "prefixes": [
              "pref"
            "source_ips": [
              "1.1.1.1",
              "1.2.2.0/24"
            "usernames": [
              "user1"
        "effect": "allow",
        "principals": [
          "user1",
          "group/grp1",
          "nasgroup/group1"
        "resources": [
          "bucket1",
          "bucket1/*"
        "sid": "Full_Access_To_User1!"
  "qos_policy": {
    "max_throughput": [
      "900KB/s",
      "500MB/s",
      "120GB/s",
      "5000IOPS",
      "5000IOPS,500KB/s",
      "2500IOPS,100MB/s",
      "1000IOPS,25MB/s"
    "max_throughput_iops": 10000,
    "max_throughput_mbps": 500,
    "min_throughput": [
      "900KB/s",
      "500MB/s",
      "120GB/s",
      "5000IOPS",
      "5000IOPS,500KB/s",
      "2500IOPS,100MB/s",
      "1000IOPS,25MB/s"
    "min_throughput_iops": 2000,
    "min_throughput_mbps": 500,
    "name": "performance",
  "retention": {
    "default_period": "P10Y",
    "mode": "governance"
  "role": "string",
  "size": 214748364800,
  "snapshot_policy": {
    "name": "default-1weekly",
    "uuid": "3675af31-431c-12fa-114a-20675afebc12"
  "snapshot_restore": {
    "snapshot": "string",
    "state": "string"
  "storage_service_level": "value",
  "svm": {
    "name": "svm1",
  "type": "s3",
  "uuid": "414b29a1-3b26-11e9-bd58-0050568ea055",
  "versioning_state": "enabled",
  "volume": {
    "name": "volume1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error code Message
92405777
"Failed to create bucket "{bucket name}" for SVM "{svm.name}". Reason: {Reason of failure}. ";
92405785
"Bucket name "{bucket name}" contains invalid characters or invalid character combinations. Valid characters for a bucket name are 0-9, a-z, ".", and "-". Invalid character combinations are ".-", "-.", and "..". ";
92405786
"Bucket name "{bucket name}" is not valid. Bucket names must have between 3 and 63 characters. ";
92405811
"Failed to create bucket "{bucket name}" for SVM "{svm.name}". Wait a few minutes and try the operation again.";
92405812
"Failed to create the object store volume. Reason: {Reason for failure}.";
92405819
"Cannot provision an object store server volume for bucket "{bucket name}" in SVM "{svm.name}" on the following aggregates because they are SnapLock aggregates: {List of aggregates.name}.";
92405820
"Failed to check whether the aggregate "{aggregates.name}" is a FabricPool. Reason: {Reason for failure}.";
92405821
"Cannot provision an object store server volume for bucket "{bucket name}" in SVM "{svm.name}" on the following aggregates because they are FabricPool: {List of aggregates.name}.";
92405827
"Internal Error. Unable to generate object store volume name.";
92405857
"One or more aggregates must be specified if "constituents_per_aggregate" is specified.";
92405858
"Failed to "create" the "bucket" because the operation is only supported on data SVMs.";
92405859
"The specified "aggregates.uuid" "{aggregates.uuid}" does not exist.";
92405860
"The specified "aggregates.name" "{aggregates.name}" and "aggregates.uuid" "{aggregates.uuid}" refer to different aggregates.";
92405861
"The specified SVM UUID or bucket UUID does not exist.";
92405863
"An error occurs when creating an access policy. The reason for failure is detailed in the error message.";
92405863
"Failed to create lifecycle management rules for bucket "s3bucket1". Reason: {Reason of failure}. ";
92405891
The resources specified in the access policy are not valid. Valid ways to specify a resource are *, <bucket-name>, <bucket-name>/…​/…​. Valid characters for a resource are 0-9, A-Z, a-z, _, +, comma, ;, :, =, ., &, @,?, (, ), single quote, *, !, - and $.
string
aggregates
Aggregate
name
string
uuid
string
access
string
Specifies read and write access types.
permission
string
Specifies allow and deny permission types.
rules
Information about the CORS rule of an S3 bucket.
allowed_headers
array[string]
An array of HTTP headers allowed in the cross-origin requests.
allowed_methods
array[string]
An array of HTTP methods allowed in the cross-origin requests.
allowed_origins
array[string]
List of origins from where a cross-origin request is allowed to originate from for the S3 bucket.
expose_headers
array[string]
List of extra headers sent in the response that customers can access from their applications.
id
string
Bucket CORS rule identifier. The length of the name can range from 0 to 256 characters.
max_age_seconds
integer
The time in seconds for your browser to cache the preflight response for the specified resource.
cors
rules
array[rules]
Specifies an object store bucket CORS rule.
encryption
enabled
boolean
Specifies whether encryption is enabled on the bucket. By default, encryption is disabled on a bucket. This field cannot be specified in a POST method.
abort_incomplete_multipart_upload
Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket. It cannot be specified with tags.
after_initiation_days
integer
Number of days of initiation after which uploads can be aborted.
expiration
Specifies a way to perform expiration action on filtered objects within a bucket.
expired_object_delete_marker
boolean
Cleanup object delete markers.
object_age_days
integer
Number of days since creation after which objects can be deleted. This cannot be used along with object_expiry_date.
object_expiry_date
string
Specific date from when objects can expire. This cannot be used with object_age_days.
non_current_version_expiration
Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket.
new_non_current_versions
integer
Number of latest non-current versions to be retained.
non_current_days
integer
Number of days after which non-current versions can be deleted.
object_filter
Specifies a way to filter objects within a bucket.
prefix
string
A prefix that is matched against object-names within a bucket.
size_greater_than
integer
Size of the object greater than specified for which the corresponding lifecycle rule is to be applied.
size_less_than
integer
Size of the object smaller than specified for which the corresponding lifecycle rule is to be applied.
tags
array[string]
An array of key-value paired tags of the form {tag} or {tag=value}.
svm
Specifies the name of the SVM where this bucket exists.
name
string
uuid
string
rules
Information about the lifecycle management rule of a bucket.
bucket_name
string
enabled
boolean
Specifies whether or not the associated rule is enabled.
expiration
expiration
name
string
Bucket lifecycle management rule identifier. The length of the name can range from 0 to 256 characters.
object_filter
object_filter
svm
svm
uuid
string
rules
array[rules]
Specifies an object store lifecycle management policy.
s3_bucket_policy_condition
Information about policy conditions based on various condition operators and condition keys.
delimiters
array[string]
An array of delimiters that are compared with the delimiter value specified at the time of execution of an S3-based command, using the condition operator specified.
max_keys
array[integer]
An array of maximum keys that are allowed or denied to be retrieved using an S3 list operation, based on the condition operator specified.
operator
string
Condition operator that is applied to the specified condition key.
prefixes
array[string]
An array of prefixes that are compared with the input prefix value specified at the time of execution of an S3-based command, using the condition operator specified.
source_ips
array[string]
An array of IP address ranges that are compared with the IP address of a source command at the time of execution of an S3-based command, using the condition operator specified.
usernames
array[string]
An array of usernames that a current user in the context is evaluated against using the condition operators.
s3_bucket_policy_statement
Specifies information about a single access permission.
actions
array[string]
conditions
array[s3_bucket_policy_condition]
Specifies bucket policy conditions.
effect
string
Specifies whether access is allowed or denied when a user requests the specific action. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access.
principals
array[string]
resources
array[string]
sid
string
Specifies the statement identifier used to differentiate between statements. The SID length can range from 1 to 256 characters.
policy
statements
array[s3_bucket_policy_statement]
Specifies bucket access policy statement.
destination
is_cloud
boolean
Specifies whether a bucket is protected within the Cloud. This field cannot be specified using a POST method.
is_external_cloud
boolean
Specifies whether a bucket is protected on external Cloud providers. This field cannot be specified using a POST method.
is_ontap
boolean
Specifies whether a bucket is protected within ONTAP. This field cannot be specified using a POST method.
  • Default value: 1
  • readOnly: 1
  • Introduced in: 9.10
  • x-nullable: true
protection_status
destination
destination
is_protected
boolean
Specifies whether a bucket is a source and if it is protected within ONTAP and/or an external cloud. This field cannot be specified using a POST method.
  • Default value: 1
  • readOnly: 1
  • x-nullable: true
qos_policy
max_throughput
string
Specifies the maximum throughput in Kilobytes per sec, Megabytes per sec or Gigabytes per sec along with or without IOPS. 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when either max_throughput_mbps or max_throughput_iops are set during POST or PATCH. During GET, the returned value is rounded to the largest unit with a value greater than 1.
max_throughput_iops
integer
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when max_throughput is set during POST or PATCH.
max_throughput_mbps
integer
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when max_throughput is set during POST or PATCH.
min_throughput
string
Specifies the minimum throughput in Kilobytes per sec, Megabytes per sec or Gigabytes per sec along with or without IOPS. 0 means none.Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when either min_throughput_mbps or min_throughput_iops are set during POST or PATCH. During GET, the returned value is rounded to the largest unit with a value greater than 1.
min_throughput_iops
integer
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when min_throughput is set during POST or PATCH.
min_throughput_mbps
integer
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.This cannot be set when min_throughput is set during POST or PATCH.
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
retention
default_period
string
Specifies the default retention period that is applied to objects while committing them to the WORM state without an associated retention period. The retention period can be in years, or days. The retention period value represents a duration and must be specified in the ISO-8601 duration format. A period specified for years and days is represented in the ISO-8601 format as "PY" and "PD" respectively, for example "P10Y" represents a duration of 10 years. The period string must contain only a single time element that is, either years, or days. A duration which combines different periods is not supported, for example "P1Y10D" is not supported.
mode
string
The lock mode of the bucket. compliance ‐ A SnapLock Compliance (SLC) bucket provides the highest level of WORM protection and an administrator cannot destroy a compliance bucket if it contains unexpired WORM objects. governance ‐ An administrator can delete a Governance bucket. no_lock ‐ Indicates the bucket does not support object locking.
snapshot_policy
name
string
Specifies the name of the snapshot policy.
uuid
string
Specifies the unique identifier of the snapshot policy.
snapshot_restore
objects_remaining
integer
Remaining objects to be restored for the bucket
progress
integer
Snapshot restore progress in percent
snapshot
string
Name of the snapshot being restored for the bucket
state
string
Snapshot restore state of the bucket
svm
name
string
uuid
string
volume
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
s3_bucket
A bucket is a container of objects. Each bucket defines an object namespace. S3 requests specify objects using a bucket-name and object-name pair. An object resides within a bucket.
aggregates
array[aggregates]
allowed
boolean
comment
string
integer
cors
cors
encryption
encryption
is_consistent_etag
boolean
is_nas_path_mutable
boolean
logical_used_size
integer
name
string
nas_path
string
policy
policy
protection_status
protection_status
qos_policy
qos_policy
retention
retention
role
string
size
integer
snapshot_policy
snapshot_policy
snapshot_restore
snapshot_restore
string
svm
svm
type
string
boolean
uuid
string
versioning_state
string
volume
volume
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
