REST API reference
Create the S3 bucket configuration for an SVM
Creates an S3 bucket configuration for a Storage Virtual Machine (SVM), establishing the necessary setup for storing and accessing objects within ONTAP. This configuration allows you to specify parameters such as aggregates, bucket size, and QoS policies to tailor the storage solution to your requirements.
HTTP method and endpoint
POST /protocols/s3/buckets
Introduced in
ONTAP 9.8
Usage notes
Creates the S3 bucket configuration of an SVM.
Important notes
  • Each SVM can have one or more bucket configurations.
  • Aggregate lists should be specified explicitly. If not specified, then the bucket is auto-provisioned as a FlexGroup volume.
  • Constituents per aggregate specifies the number of components (or FlexVol volumes) per aggregate. Is specified only when an aggregate list is explicitly defined.
  • An access policy can be created along with a bucket create. If creating an access policy fails, bucket configurations are saved and the access policy can be created using the PATCH endpoint.
  • "qos_policy" can be specified if a bucket needs to be attached to a QoS group policy during creation time.
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the bucket configuration.
  • name - Bucket name that is to be created.
  • aggregates - List of aggregates for the FlexGroup volume on which the bucket is hosted on.
  • constituents_per_aggregate - Number of constituents per aggregate.
  • size - Specifying the bucket size is recommended.
  • policy - Specifying a policy enables users to perform operations on buckets; specifying the resource permissions is recommended.
  • qos_policy - A QoS policy for buckets.
Default property values
  • size - 800MB
  • comment - ""
  • aggregates - No default value.
  • constituents_per_aggregate - 4 , if an aggregates list is specified. Otherwise, no default value.
  • policy.statements.actions - GetObject, PutObject, DeleteObject, ListBucket, ListBucketMultipartUploads, ListMultipartUploadParts, GetObjectTagging, PutObjectTagging, DeleteObjectTagging.
  • policy.statements.principals - all S3 users and groups in the SVM.
  • policy.statements.resources - all objects in the bucket.
  • policy.statements.conditions - list of bucket policy conditions.
  • vserver object-store-server bucket create
  • vserver object-store-server bucket policy statement create
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
aggregates
array[aggregates]
A list of aggregates for FlexGroup volume constituents where the bucket is hosted. If this option is not specified, the bucket is auto-provisioned as a FlexGroup volume.
comment
string
Can contain any additional information about the bucket being created or modified.
integer
Specifies the number of constituents or FlexVol volumes per aggregate. A FlexGroup volume consisting of all such constituents across all specified aggregates is created. This option is used along with the aggregates option and cannot be used independently.
encryption
encryption
logical_used_size
integer
Specifies the bucket logical used size up to this point.
name
string
Specifies the name of the bucket. Bucket name is a string that can only contain the following combination of ASCII-range alphanumeric characters 0-9, a-z, ".", and "-".
policy
policy
A policy is an object associated with a bucket. It defines resource (bucket, folder, or object) permissions. These policies get evaluated when an S3 user makes a request by executing a specific command. The user must be part of the principal (user or group) specified in the policy. Permissions in the policies determine whether the request is allowed or denied.
qos_policy
qos_policy
Specifes "qos_policy.max_throughput_iops" and/or "qos_policy.max_throughput_mbps" or "qos_policy.min_throughput_iops". Specifes "min_throughput_iops" is only supported on volumes hosted on a node that is flash optimized. A pre-created QoS policy can also be used by specifying "qos_policy.name" or "qos_policy.uuid" properties. Setting or assigning a QoS policy to a bucket is not supported if its containing volume or SVM already has a QoS policy attached.
size
integer
Specifies the bucket size in bytes; ranges from 80MB to 64TB.
storage_service_level
string
Specifies the storage service level of the FlexGroup volume on which the bucket should be created. Valid values are "value", "performance" or "extreme".
svm
svm
uuid
string
Specifies the unique identifier of the bucket.
volume
volume
Specifies the FlexGroup volume name and UUID where the bucket is hosted.
Example request
  "aggregates": [
      "name": "aggr1",
  "comment": "S3 bucket.",
  "constituents_per_aggregate": "4",
  "logical_used_size": 0,
  "name": "bucket1",
  "policy": {
    "statements": [
        "actions": [
          "GetObject",
          "PutObject",
          "DeleteObject",
          "ListBucket"
        "conditions": [
            "delimiters": [
            "max_keys": [
              "1000"
            "operator": "ip_address",
            "prefixes": [
              "pref"
            "source_ips": [
              "1.1.1.1",
              "1.2.2.0/24"
            "usernames": [
              "user1"
        "effect": "allow",
        "principals": [
          "user1",
          "group/grp1"
        "resources": [
          "bucket1",
          "bucket1/*"
        "sid": "FullAccessToUser1"
  "qos_policy": {
    "max_throughput_iops": "10000",
    "max_throughput_mbps": "500",
    "min_throughput_iops": "2000",
    "min_throughput_mbps": "500",
    "name": "performance",
  "size": "1677721600",
  "storage_service_level": "value",
  "svm": {
    "name": "svm1",
  "uuid": "414b29a1-3b26-11e9-bd58-0050568ea055",
  "volume": {
    "name": "volume1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error code Message
92405777
"Failed to create bucket "{bucket name}" for SVM "{svm.name}". Reason: {Reason of failure}. ";
92405785
"Bucket name "{bucket name}" contains invalid characters. Valid characters for a bucket name are 0-9, a-z, ".", and "-". ";
92405786
"Bucket name "{bucket name}" is not valid. Bucket names must have between 3 and 63 characters. ";
92405811
"Failed to create bucket "{bucket name}" for SVM "{svm.name}". Wait a few minutes and try the operation again.";
92405812
"Failed to create the object store volume. Reason: {Reason for failure}.";
92405819
"Cannot provision an object store server volume for bucket "{bucket name}" in SVM "{svm.name}" on the following aggregates because they are SnapLock aggregates: {List of aggregates.name}.";
92405820
"Failed to check whether the aggregate "{aggregates.name}" is a FabricPool. Reason: {Reason for failure}.";
92405821
"Cannot provision an object store server volume for bucket "{bucket name}" in SVM "{svm.name}" on the following aggregates because they are FabricPool: {List of aggregates.name}.";
92405827
"Internal Error. Unable to generate object store volume name.";
92405857
"One or more aggregates must be specified if "constituents_per_aggregate" is specified.";
92405858
"Failed to "create" the "bucket" because the operation is only supported on data SVMs.";
92405859
"The specified "aggregates.uuid" "{aggregates.uuid}" does not exist.";
92405860
"The specified "aggregates.name" "{aggregates.name}" and "aggregates.uuid" "{aggregates.uuid}" refer to different aggregates.";
92405861
"The specified SVM UUID or bucket UUID does not exist.";
92405863
"An error occurs when creating an access policy. The reason for failure is detailed in the error message.";
92405891
The resources specified in the access policy are not valid. Valid ways to specify a resource are *, <bucket-name>, <bucket-name>/…​/…​. Valid characters for a resource are 0-9, A-Z, a-z, _, +, comma, ;, :, =, ., &, @,?, (, ), single quote, *, !, - and $.
92405894
"Statements, principals and resources list can have a maximum of 10 entries.";
92405897
The principals specified in the access policy are not in the correct format. User name must be in between 1 and 64 characters. Valid characters for a user name are 0-9, A-Z, a-z, _, +, =, comma, ., @, and - .
92405898
"The SID specified in the access policy is not valid. Valid characters for a SID are 0-9, A-Z and a-z.";
string
aggregates
Aggregate
name
string
uuid
string
encryption
enabled
boolean
Specifies whether encryption is enabled on the bucket. By default, encryption is disabled on a bucket.
s3_bucket_policy_condition
Information about policy conditions based on various condition operators and condition keys.
delimiters
array[string]
An array of delimiters that are compared with the delimiter value specified at the time of execution of an S3-based command, using the condition operator specified.
max_keys
array[integer]
An array of maximum keys that are allowed or denied to be retrieved using an S3 list operation, based on the condition operator specified.
operator
string
Condition operator that is applied to the specified condition key.
prefixes
array[string]
An array of prefixes that are compared with the input prefix value specified at the time of execution of an S3-based command, using the condition operator specified.
source_ips
array[string]
An array of IP address ranges that are compared with the IP address of a source command at the time of execution of an S3-based command, using the condition operator specified.
usernames
array[string]
An array of usernames that a current user in the context is evaluated against using the condition operators.
s3_bucket_policy_statement
Specifies information about a single access permission.
actions
array[string]
conditions
array[s3_bucket_policy_condition]
Specifies bucket policy conditions.
effect
string
Specifies whether access is allowed or denied when a user requests the specific action. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access.
principals
array[string]
resources
array[string]
sid
string
Specifies the statement identifier used to differentiate between statements.
policy
statements
array[s3_bucket_policy_statement]
Specifies bucket access policy statement.
qos_policy
max_throughput_iops
integer
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
max_throughput_mbps
integer
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_iops
integer
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_mbps
integer
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
svm
name
string
The name of the SVM.
uuid
string
volume
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
s3_bucket
A bucket is a container of objects. Each bucket defines an object namespace. S3 requests specify objects using a bucket-name and object-name pair. An object resides within a bucket.
aggregates
array[aggregates]
comment
string
integer
encryption
encryption
logical_used_size
integer
name
string
policy
policy
qos_policy
qos_policy
size
integer
string
svm
svm
uuid
string
volume
volume
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
