REST API reference
Create a cluster network security certificate configuration
POST /security/cluster-network/certificates
Introduced In: 9.18
Specifies the certificate configuration for cluster network security for a given node.
Required properties
  • 'node' - The node to which the certificate will be assigned.
  • 'name' - The certificate name.
  • 'security cluster-network certificate create'
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
certificate
security_certificate_reference
Security certificate object reference
node
node_reference
Example request
  "certificate": {
    "name": "string",
  "node": {
    "name": "node1",
Status: 201, Created
certificate
node
node_reference
  "certificate": {
    "name": "string",
  "node": {
    "name": "node1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
70320128
Modifying the cluster network security configuration requires an effective cluster version of ONTAP 9.18.1 or later.
70320132
The cluster has an out of quorum node, wait until all nodes are in quorum before modifying the cluster network security configuration.
70320137
The specified certificate was not found on the admin SVM
string
name
string
Certificate name
uuid
string
Certificate UUID
node_reference
name
string
uuid
string
security_cluster_network_certificates
Manages the cluster network security certificate configuration.
certificate
node
node_reference
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
