Create a cluster network security certificate configuration
Configures a cluster network security certificate for a specific node. This allows you to manage the security settings for network communication within the cluster.
HTTP method and endpoint
POST /security/cluster-network/certificates
Introduced in
ONTAP 9.18
Usage notes
Specifies the certificate configuration for cluster network security for a given node.
Required properties
node.uuid- The UUID of the node to which the certificate will be assigned. -
certificate.name-The certificate name.
Related ONTAP commands
'security cluster-network certificate create'
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
certificate |
Security certificate object reference |
node |
Example request
"certificate": {
"name": "string",
"node": {
"name": "node1",
Status: 201, Created
certificate |
node |
"certificate": {
"name": "string",
"node": {
"name": "node1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
70320128 |
Modifying the cluster network security configuration requires an effective cluster version of ONTAP 9.18.1 or later. |
70320132 |
The cluster has an out of quorum node, wait until all nodes are in quorum before modifying the cluster network security configuration. |
70320137 |
The specified certificate was not found on the admin SVM |
href |
string |
_links
security_certificate_reference
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
node_reference
name |
string |
uuid |
string |
security_cluster_network_certificates
Manages the cluster network security certificate configuration.
certificate |
node |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
