View CIFS active file sessions
Overview
ONTAP cifs sessions file show functionality is used to provide a list of currently opened files.<h2/>
Information on the open files
Lists all files opened in current session.
Example
Retrieving established open file information
To retrieve the list of open files, use the following API. Note that return_records=true.
# The API:
GET /protocols/cifs/session/files
# The call:
curl -X GET "https://<cluster-mgmt-ip>/api/protocols/cifs/session/files?fields=*&return_timeout=15&return_records=true" -H "accept: application/json"
# The response:
"records": [
"node": {
"uuid": "a5f65ec0-3550-11ee-93c5-005056ae78de",
"name": "sti220-vsim-sr050u"
"svm": {
"name": "vs0",
"uuid": "80e795f4-3553-11ee-9f97-005056ae78de"
"identifier": 109,
"connection": {
"identifier": 103985,
"count": 1
"session": {
"identifier": 10878444899913433090
"type": "regular",
"open_mode": "r",
"volume": {
"uuid": "8384f6ae-3553-11ee-a3c3-005056ae0dd5",
"name": "root_vs0"
"share": {
"name": "sh1",
"mode": "r"
"path": "first_file.txt",
"continuously_available": "no",
"range_locks_count": 0
"node": {
"svm": {
"name": "vs0",
"identifier": 110,
"connection": {
"count": 1
"session": {
"type": "regular",
"open_mode": "r",
"volume": {
"name": "root_vs0"
"share": {
"name": "sh1",
"mode": "r"
"path": "second_file.txt",
"num_records": 2
Retrieving specific open file Information
# The API:
GET /protocols/cifs/session/files/{node.uuid}/{svm.uuid}/{file.identifier}/{connection.identifier}/{session_id}
# The call:
curl -X GET "https://<cluster-mgmt-ip>/api/protocols/cifs/session/files/a5f65ec0-3550-11ee-93c5-005056ae78de/80e795f4-3553-11ee-9f97-005056ae78de/109/103985/10878444899913433090"
# The response:
"node": {
"svm": {
"uuid": "80e795f4-3553-11ee-9f97-005056ae78de",
"name": "vs0"
"identifier": 109,
"connection": {
"count": 1
"session": {
"identifier": 10878444899913433000
"type": "regular",
"open_mode": "r",
"volume": {
"name": "root_vs0"
"share": {
"name": "sh1",
"mode": "r"
Closing a specific file based on file.identifier, connection.identifier and session_id
The file being closed is identified by the UUID of its SVM, the corresponding file.identifier, connection.identifier and session_id.
# The API:
DELETE /protocols/cifs/session/files/{node.uuid}/{svm.uuid}/{file.identifier}/{connection.identifier}/{session_id}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/cifs/session/files/a5f65ec0-3550-11ee-93c5-005056ae78de/80e795f4-3553-11ee-9f97-005056ae78de/109/103985/10878444899913433090" -H "accept: application/json"
