REST API reference
Protocols cifs session files endpoint overview
Overview
ONTAP cifs sessions file show functionality is used to provide a list of currently opened files.<h2/>
Information on the open files
  • Lists all files opened in current session.
Example
Retrieving established open file information
To retrieve the list of open files, use the following API. Note that return_records=true.
# The API:
GET /protocols/cifs/session/files
# The call:
curl -X GET "https://<cluster-mgmt-ip>/api/protocols/cifs/session/files?fields=*&return_timeout=15&return_records=true" -H "accept: application/json"
# The response:
"records": [
                           "node": {
                             "uuid": "a5f65ec0-3550-11ee-93c5-005056ae78de",
                             "name": "sti220-vsim-sr050u"
                            "svm": {
                              "name": "vs0",
                              "uuid": "80e795f4-3553-11ee-9f97-005056ae78de"
                            "identifier": 109,
                            "connection": {
                              "identifier": 103985,
                              "count": 1
                            "session": {
                              "identifier": 10878444899913433090
                            "type": "regular",
                            "open_mode": "r",
                            "volume": {
                              "uuid": "8384f6ae-3553-11ee-a3c3-005056ae0dd5",
                              "name": "root_vs0"
                            "share": {
                              "name": "sh1",
                              "mode": "r"
                            "path": "first_file.txt",
                            "continuously_available": "no",
                            "range_locks_count": 0
                            "node": {
                            "svm": {
                              "name": "vs0",
                            "identifier": 110,
                            "connection": {
                              "count": 1
                            "session": {
                            "type": "regular",
                            "open_mode": "r",
                            "volume": {
                              "name": "root_vs0"
                             "share": {
                               "name": "sh1",
                               "mode": "r"
                             "path": "second_file.txt",
           "num_records": 2
Retrieving specific open file Information
# The API:
GET /protocols/cifs/session/files/{node.uuid}/{svm.uuid}/{file.identifier}/{connection.identifier}/{session_id}
# The call:
curl -X GET "https://<cluster-mgmt-ip>/api/protocols/cifs/session/files/a5f65ec0-3550-11ee-93c5-005056ae78de/80e795f4-3553-11ee-9f97-005056ae78de/109/103985/10878444899913433090"
# The response:
              "node": {
              "svm": {
                "uuid": "80e795f4-3553-11ee-9f97-005056ae78de",
                "name": "vs0"
              "identifier": 109,
              "connection": {
                "count": 1
              "session": {
                "identifier": 10878444899913433000
              "type": "regular",
              "open_mode": "r",
              "volume": {
                "name": "root_vs0"
              "share": {
                "name": "sh1",
                "mode": "r"
Closing a specific file based on file.identifier, connection.identifier and session_id
The file being closed is identified by the UUID of its SVM, the corresponding file.identifier, connection.identifier and session_id.
# The API:
DELETE /protocols/cifs/session/files/{node.uuid}/{svm.uuid}/{file.identifier}/{connection.identifier}/{session_id}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/cifs/session/files/a5f65ec0-3550-11ee-93c5-005056ae78de/80e795f4-3553-11ee-9f97-005056ae78de/109/103985/10878444899913433090" -H "accept: application/json"
