REST API reference
Manage cluster network security configuration
Overview
You can use the security cluster-network API endpoints to modify the cluster network security configuration. The following operations are supported:
  • GET to retrieve the cluster network security status: GET security/cluster-network
  • PATCH to update the cluster network security configuration: PATCH security/cluster-network
