REST API reference
Manage cluster network security configuration
Use the security cluster-network API endpoints to retrieve and modify the cluster network security configuration. Access these endpoints to ensure your network maintains robust security settings, including enabling or disabling TLS and IPsec modes.
Overview
You can use the security cluster-network API endpoints to retrieve and modify the cluster network security configuration. The following operations are supported:
  • GET to retrieve the cluster network security status: GET security/cluster-network
  • PATCH to update the cluster network security configuration: PATCH security/cluster-network
Retrieving the cluster network security configuration
# The API:
GET /api/security/cluster-network
# The call:
curl -X GET "https://<mgmt-ip>/api/security/cluster-network" -H "accept: application/json"
# The response:
"enabled": true,
"mode": "tls",
"status": "READY",
"ipsec_status": "READY",
    "href": "/api/security/cluster-network"
Enabling cluster network security with TLS and IPsec mode
# The API:
PATCH /api/security/cluster-network
# The call:
curl -X PATCH "https://<mgmt-ip>/api/security/cluster-network" -H "accept: application/json" -H "Content-Type: application/json" -d '{"enabled": true, "mode": "tls_ipsec"}'
# The response:
HTTP/1.1 200 OK
Disabling cluster network security
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/security/cluster-network" -H "accept: application/json" -H "Content-Type: application/json" -d '{"enabled": false}'
# The response:
HTTP/1.1 200 OK
