Retrieve qtree properties
GET /storage/qtrees/{volume.uuid}/{id}
Retrieves properties for a specific qtree identified by the volume.uuid and the id in the api path.
Related ONTAP commands
qtree show
Learn more
volume.uuid |
string |
path |
True |
Volume UUID |
id |
string |
path |
True |
Qtree ID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
export_policy |
Export Policy |
id |
integer |
The identifier for the qtree, unique within the qtree's volume. |
name |
string |
The name of the qtree. Required in POST; optional in PATCH. |
path |
string |
Client visible path to the qtree. This field is not available if the volume does not have a junction-path configured. Not valid in POST or PATCH. |
security_style |
string |
Security style. Valid in POST or PATCH. |
svm |
Required in POST |
unix_permissions |
integer |
The UNIX permissions for the qtree. Valid in POST or PATCH. |
volume |
Required in POST |
"href": "/api/resourcelink"
"export_policy": {
"id": 100,
"name": "default"
"id": 1,
"name": "string",
"path": "/volume3/qtree1",
"security_style": "string",
"svm": {
"name": "svm1",
"unix_permissions": 493,
"volume": {
"name": "volume1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
918235 |
A volume with UUID was not found. |
5242956 |
Failed to obtain qtree with ID. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
export_policy
Export Policy
_links |
id |
integer |
name |
string |
svm
Required in POST
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
Required in POST
_links |
name |
string |
The name of the volume. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
