      Network http-proxy endpoint overview
Overview
Configuration of an HTTP proxy for an SVM or a Cluster IPspace.
Retrieve HTTP proxy information
The HTTP proxy GET operation retrieves all configurations for an SVM or a Cluster IPspace via '/api/cluster'.
Retrieving all fields for all HTTP proxy configurations
# The API:
/api/network/http-proxy
# The call:
curl -X GET "https://<mgmt-ip>/api/network/http-proxy?fields=*&return_records=true&return_timeout=15" -H  "accept: application/json"
# The response:
"records": [
    "uuid": "4133a1fc-7228-11e9-b40c-005056bb4f0c",
    "svm": {
        "name": "vs1",
    "server": "server1.example.com",
    "port": 3128
    "uuid": "96219ce3-7214-11e9-828c-005056bb4f0c",
    "svm": {
        "name": "cluster-1",
    "ipspace": {
        "uuid": "7433520f-7214-11e9-828c-005056bb4f0c",
        "name": "Default"
    "server": "1.1.1.",
    "port": 3128
"num_records": 2
Retrieving the HTTP proxy configuration for a specific SVM
# The API:
/api/network/http-proxy/{uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/network/http-proxy/96219ce3-7214-11e9-828c-005056bb4f0c" -H  "accept: application/json"
# The response
"svm": {
"ipspace": {
    "name": "Default"
"server": "1.1.1.1",
"port": 3128
Creating an HTTP proxy configuration
You can use the HTTP proxy POST operation to create an HTTP proxy configuration for the specified SVM.
Creating an HTTP proxy configuration for a particular SVM
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/network/http-proxy" -H  "accept: application/json" -H  "Content-Type: application/json" -d "{    \"port\": 3128,  \"server\": \"1.1.1.1\",  \"svm\": {      \"name\": \"cluster-1\"  }}"
Creating an HTTP proxy configuration for a particular IPspace
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/network/http-proxy" -H  "accept: application/json" -H  "Content-Type: application/json" -d "{  \"ipspace\": {    \"name\": \"Default\"  },  \"port\": 3128,  \"server\": \"1.1.1.1\"}"
Update an HTTP proxy configuration for a specified SVM
You can use the HTTP proxy PATCH operation to update the HTTP proxy configuration for the specified SVM.
Example
The following example shows how a PATCH operation is used to update an HTTP proxy configuration for a specific SVM:
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/network/http-proxy/96219ce3-7214-11e9-828c-005056bb4f0c" -H  "accept: application/json" -H  "Content-Type: application/json" -d "{    \"port\": 3128,  \"server\": \"server2.example.com\"}"
Delete an HTTP proxy configuration for a specified SVM
You can use the HTTP proxy DELETE operation to delete the HTTP proxy configuration for the specified SVM.
Example
The following example shows how a DELETE operation is used to delete an HTTP proxy configuration for a specific SVM:
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/network/http-proxy/96219ce3-7214-11e9-828c-005056bb4f0c" -H  "accept: application/json"
