Update an S3 bucket configuration for an SVM
PATCH /protocols/s3/services/{svm.uuid}/buckets/{uuid}
Updates the S3 bucket configuration of an SVM.
Important notes
The following fields can be modified for a bucket:
comment- Any information related to the bucket. -
size- Bucket size.
Related ONTAP commands
vserver object-store-server bucket modify
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When doing a POST, PATCH, or DELETE operation on a single record, the default is 0 seconds. This means that if an asynchronous operation is started, the server immediately returns HTTP code 202 (Accepted) along with a link to the job. If a non-zero value is specified for POST, PATCH, or DELETE operations, ONTAP waits that length of time to see if the job completes so it can return something other than 202. |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
uuid |
string |
path |
True |
The unique identifier of the bucket. |
Request Body
| Name | Type | Description |
comment |
string |
Can contain any additional information about the bucket being created or modified. |
encryption |
logical_used_size |
integer |
Specifies the bucket logical used size up to this point. |
size |
integer |
Specifies the bucket size in bytes; ranges from 80MB to 64TB. |
svm |
uuid |
string |
Specifies the unique identifier of the bucket. |
volume |
Specifies the FlexGroup volume name and UUID where the bucket is hosted. |
Example request
"comment": "S3 bucket.",
"logical_used_size": 0,
"size": 1677721600,
"svm": {
"href": "/api/resourcelink"
"name": "svm1",
"uuid": "414b29a1-3b26-11e9-bd58-0050568ea055",
"volume": {
"name": "volume1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error code | Message |
92405778 |
"Failed to modify bucket "{bucket name}" for SVM "{svm.name}". Reason: {Reason for failure}. "; |
92405846 |
"Failed to modify the object store volume. Reason: {Reason for failure}."; |
92405811 |
"Failed to modify bucket "{bucket name}" for SVM "{svm.name}". Wait a few minutes and try the operation again."; |
92405858 |
"Failed to "modify" the "bucket" because the operation is only supported on data SVMs."; |
92405861 |
"The specified SVM UUID or bucket UUID does not exist."; |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
aggregates
Aggregate
_links |
name |
string |
uuid |
string |
encryption
enabled |
boolean |
Specifies whether encryption is enabled on the bucket. By default, encryption is disabled on a bucket. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
s3_bucket_svm
A bucket is a container of objects. Each bucket defines an object namespace. S3 requests specify objects using a bucket-name and object-name pair. An object resides within a bucket.
comment |
string |
encryption |
logical_used_size |
integer |
size |
integer |
svm |
uuid |
string |
volume |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
