Delete trace results
DELETE /protocols/file-access-tracing/events/{node.uuid}/{svm.uuid}/{index}
Introduced In: 9.8
Deletes trace results.
Related ONTAP commands
vserver security trace result delete
node.uuid |
string |
path |
True |
Node UUID. |
index |
integer |
path |
True |
Sequence number of traced event. |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
