REST API reference
Delete an event filter rule
Deletes an event filter rule to remove specific filtering criteria for events, streamlining event management.
HTTP method and endpoint
DELETE /support/ems/filters/{name}/rules/{index}
Introduced in
ONTAP 9.6
  • event filter rule delete
name
string
path
True
Filter name
index
string
path
True
Filter index
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
983091
A default rule cannot be removed
983092
The index of the rule provided is outside the allowed range for the filter provided
983095
The rule index provided is invalid for the filter provided
983110
There are no user defined rules in the filter provided
983113
Default filters cannot be modified or removed
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
