Delete an event filter rule
Deletes an event filter rule to remove specific filtering criteria from your event management configuration.
HTTP method and endpoint
DELETE /support/ems/filters/{name}/rules/{index}
Introduced in
ONTAP 9.6
Related ONTAP commands
event filter rule delete
name |
string |
path |
True |
Filter name |
index |
string |
path |
True |
Filter rule index |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983091 |
A default rule cannot be removed |
983092 |
The index of the rule provided is outside the allowed range for the filter provided |
983095 |
The rule index provided is invalid for the filter provided |
983110 |
There are no user defined rules in the filter provided |
983113 |
Default filters cannot be modified or removed |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
