Retrieve NTP symmetric authentication key details
Retrieves details of a specific NTP symmetric authentication key using its numeric identifier or index. This is useful for managing time-service configurations and ensuring accurate time synchronization across your network.
HTTP method and endpoint
GET /cluster/ntp/keys/{id}
Introduced in
ONTAP 9.7
Usage notes
Retrieves the details of a specific NTP symmetric authentication key by numeric identifier or index (ID).
Related ONTAP commands
cluster time-service ntp key show
Learn more
id |
integer |
path |
True |
Key identifier |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
digest_type |
string |
The type of cryptographic hash used to create and verify the NTP's message authentication code appended to each NTP packet header. |
id |
integer |
NTP symmetric authentication key identifier or index number (ID). This ID is included in the NTP cryptographic hash encoded header. |
value |
string |
A hexadecimal digit string that represents the cryptographic key that is shared with the remote NTP server. The current expected length is 40 characters. Use the cryptographic key and key ID to create a unique hash value used to authenticate the rest of the NTP data. |
"href": "/api/resourcelink"
"digest_type": "sha1",
"id": "10",
"value": "da39a3ee5e6b4b0d3255bfef95601890afd80709"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
