REST API reference
Retrieve NTP symmetric authentication key details
GET /cluster/ntp/keys/{id}
Introduced In: 9.7
Retrieves the details of a specific NTP symmetric authentication key by numeric identifier or index (ID).
  • cluster time-service ntp key show
id
integer
path
True
Key identifier
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
digest_type
string
The type of cryptographic hash used to create and verify the NTP's message authentication code appended to each NTP packet header.
id
integer
NTP symmetric authentication key identifier or index number (ID). This ID is included in the NTP cryptographic hash encoded header.
value
string
A hexadecimal digit string that represents the cryptographic key that is shared with the remote NTP server. The current expected length is 40 characters.
Use the cryptographic key and key ID to create a unique hash value used to authenticate the rest of the NTP data.
      "href": "/api/resourcelink"
  "digest_type": "sha1",
  "id": 10,
  "value": "da39a3ee5e6b4b0d3255bfef95601890afd80709"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
