REST API reference
Manage cluster NTP keys
Configure NTP shared private keys to establish secure communication between ONTAP and trusted external NTP time servers. Use these endpoints to associate keys with servers and enable authentication, ensuring accurate time synchronization.
Overview
You can configure NTP to use shared private keys between ONTAP and trusted external NTP time servers.
You acquire the keys from the external NTP time servers and individual entries created for each unique key. You can use the /cluster/ntp/servers API to associate a key with an external NTP time server used by ONTAP and enable authentication.
Fields used for adding an NTP shared key
The required fields are:
  • id
  • digest_type
  • secret_key
Example
# Body
create_ntp_key.txt(body):
"id": 10,
"digest_type": "sha1",
"value": "da39a3ee5e6b4b0d3255bfef95601890afd80709"
# Request
curl -X POST "https://<mgmt-ip>/api/cluster/ntp/keys" -d "@create_ntp_key.txt"
