REST API reference
Retrieve Ethernet switch ports
Retrieves Ethernet switch port information to view the current configuration and status of each port. This can help you manage and troubleshoot network connections effectively.
HTTP method and endpoint
GET /network/ethernet/switch/ports
Introduced in
ONTAP 9.8
Usage notes
Retrieves the ethernet switch ports.
  • system switch ethernet interface show
identity.number
integer
query
False
Filter by identity.number
identity.name
string
query
False
Filter by identity.name
identity.index
integer
query
False
Filter by identity.index
mac_address
string
query
False
Filter by mac_address
duplex_type
string
query
False
Filter by duplex_type
statistics.receive_raw.errors
integer
query
False
Filter by statistics.receive_raw.errors
statistics.receive_raw.discards
integer
query
False
Filter by statistics.receive_raw.discards
statistics.receive_raw.packets
integer
query
False
Filter by statistics.receive_raw.packets
statistics.transmit_raw.errors
integer
query
False
Filter by statistics.transmit_raw.errors
statistics.transmit_raw.discards
integer
query
False
Filter by statistics.transmit_raw.discards
statistics.transmit_raw.packets
integer
query
False
Filter by statistics.transmit_raw.packets
isl
boolean
query
False
Filter by isl
remote_port.name
string
query
False
Filter by remote_port.name
remote_port.mtu
integer
query
False
Filter by remote_port.mtu
remote_port.device.node.name
string
query
False
Filter by remote_port.device.node.name
remote_port.device.node.uuid
string
query
False
Filter by remote_port.device.node.uuid
remote_port.device.shelf.uid
string
query
False
Filter by remote_port.device.shelf.uid
type
string
query
False
Filter by type
mtu
integer
query
False
Filter by mtu
vlan_id
integer
query
False
Filter by vlan_id
configured
string
query
False
Filter by configured
speed
integer
query
False
Filter by speed
switch.name
string
query
False
Filter by switch.name
state
string
query
False
Filter by state
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of Records
records
array[switch_port]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "configured": "string",
      "duplex_type": "string",
      "identity": {
        "index": 0,
        "name": "string",
        "number": 0
      "mac_address": "string",
      "mtu": 0,
      "remote_port": {
        "device": {
          "node": {
            "name": "node1",
          "shelf": {
            "uid": "7777841915827391056"
        "mtu": 0,
        "name": "string"
      "speed": 0,
      "state": "string",
      "statistics": {
        "receive_raw": {
          "discards": "100",
          "errors": "200",
          "packets": "500"
        "transmit_raw": {
          "discards": "100",
          "errors": "200",
          "packets": "500"
      "switch": {
        "name": "RTP-SS01-510R03(FOC223443KQ)"
      "type": "string",
      "vlan_id": [
        "integer"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
identity
index
integer
Interface Index.
name
string
Interface Name.
number
integer
Interface Number.
self
node
_links
_links
name
string
uuid
string
shelf
Shelf connected to this port.
_links
_links
uid
string
device
Device connected to port.
node
node
shelf
shelf
remote_port
Remote port
device
device
mtu
integer
MTU in octets
name
string
Port Name.
receive_raw
Packet receive counters for the Ethernet port.
discards
integer
Total number of discarded packets.
errors
integer
Number of packet errors.
packets
integer
Total packet count.
transmit_raw
Packet transmit counters for the Ethernet port.
discards
integer
errors
integer
packets
integer
Total packet count.
statistics
These are raw counters for the device associated with the Ethernet port.
receive_raw
receive_raw
transmit_raw
transmit_raw
switch
The name of the specified cluster or storage switch.
_links
self_link
name
string
switch_port
Ethernet Switch Port REST API
_links
self_link
configured
string
Administrative Status.
duplex_type
string
Duplex Settings.
identity
identity
isl
boolean
Is configured as an ISL link.
mac_address
string
MAC Address.
mtu
integer
MTU.
remote_port
remote_port
Remote port
speed
integer
Interface Speed(Mbps)
state
string
Operational Status.
statistics
statistics
switch
switch
type
string
Interface Type.
vlan_id
array[integer]
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
