Retrieve Ethernet switch ports
Retrieves Ethernet switch ports to give you access to configuration details for network management tasks.
HTTP method and endpoint
GET /network/ethernet/switch/ports
Introduced in
ONTAP 9.8
Related ONTAP commands
system switch ethernet interface show
Learn more
mac_address |
string |
query |
False |
Filter by mac_address |
speed |
integer |
query |
False |
Filter by speed |
duplex_type |
string |
query |
False |
Filter by duplex_type |
state |
string |
query |
False |
Filter by state |
mtu |
integer |
query |
False |
Filter by mtu |
configured |
string |
query |
False |
Filter by configured |
isl |
boolean |
query |
False |
Filter by isl |
switch.name |
string |
query |
False |
Filter by switch.name |
remote_port.device.node.uuid |
string |
query |
False |
Filter by remote_port.device.node.uuid |
remote_port.device.node.name |
string |
query |
False |
Filter by remote_port.device.node.name |
remote_port.device.shelf.uid |
string |
query |
False |
Filter by remote_port.device.shelf.uid |
remote_port.mtu |
integer |
query |
False |
Filter by remote_port.mtu |
remote_port.name |
string |
query |
False |
Filter by remote_port.name |
type |
string |
query |
False |
Filter by type |
statistics.receive_raw.packets |
integer |
query |
False |
Filter by statistics.receive_raw.packets |
statistics.receive_raw.errors |
integer |
query |
False |
Filter by statistics.receive_raw.errors |
statistics.receive_raw.discards |
integer |
query |
False |
Filter by statistics.receive_raw.discards |
statistics.transmit_raw.packets |
integer |
query |
False |
Filter by statistics.transmit_raw.packets |
statistics.transmit_raw.errors |
integer |
query |
False |
Filter by statistics.transmit_raw.errors |
statistics.transmit_raw.discards |
integer |
query |
False |
Filter by statistics.transmit_raw.discards |
identity.index |
integer |
query |
False |
Filter by identity.index |
identity.number |
integer |
query |
False |
Filter by identity.number |
identity.name |
string |
query |
False |
Filter by identity.name |
vlan_id |
integer |
query |
False |
Filter by vlan_id |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records |
records |
array[switch_port] |
"next": {
"href": "/api/resourcelink"
"records": [
"configured": "string",
"duplex_type": "string",
"identity": {
"index": 0,
"name": "string",
"number": 0
"mac_address": "string",
"mtu": 0,
"remote_port": {
"device": {
"node": {
"name": "node1",
"shelf": {
"uid": "7777841915827391056"
"mtu": 0,
"name": "string"
"speed": 0,
"state": "string",
"statistics": {
"receive_raw": {
"discards": 100,
"errors": 200,
"packets": 500
"transmit_raw": {
"discards": 100,
"errors": 200,
"packets": 500
"switch": {
"name": "RTP-SS01-510R03(FOC223443KQ)"
"type": "string",
"vlan_id": [
"integer"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
self_link
self |
identity
index |
integer |
Interface Index. |
name |
string |
Interface Name. |
number |
integer |
Interface Number. |
_links
self |
node
_links |
name |
string |
uuid |
string |
shelf
Shelf connected to this port.
_links |
uid |
string |
device
Device connected to port.
node |
shelf |
Shelf connected to this port. |
remote_port
Remote port
device |
Device connected to port. |
mtu |
integer |
MTU in octets |
name |
string |
Port Name. |
receive_raw
Packet receive counters for the Ethernet port.
discards |
integer |
Total number of discarded packets. |
errors |
integer |
Number of packet errors. |
packets |
integer |
Total packet count. |
transmit_raw
Packet transmit counters for the Ethernet port.
discards |
integer |
errors |
integer |
packets |
integer |
statistics
These are raw counters for the device associated with the Ethernet port.
receive_raw |
Packet receive counters for the Ethernet port. |
transmit_raw |
Packet transmit counters for the Ethernet port. |
switch
The name of the specified cluster or storage switch.
_links |
name |
string |
switch_port
Ethernet Switch Port REST API
_links |
configured |
string |
Administrative Status. |
duplex_type |
string |
Duplex Settings. |
identity |
isl |
boolean |
Is configured as an ISL link. |
mac_address |
string |
MAC Address. |
mtu |
integer |
MTU. |
remote_port |
Remote port |
speed |
integer |
Interface Speed(Mbps) |
state |
string |
Operational Status. |
statistics |
These are raw counters for the device associated with the Ethernet port. |
switch |
The name of the specified cluster or storage switch. |
type |
string |
Interface Type. |
vlan_id |
array[integer] |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
