REST API reference
Retrieve Ethernet switch ports
GET /network/ethernet/switch/ports
Introduced In: 9.8
Retrieves the ethernet switch ports.
  • system switch ethernet interface show
switch.name
string
query
False
Filter by switch.name
identity.breakout.physical_port
string
query
False
Filter by identity.breakout.physical_port
  • Introduced in: 9.17
identity.breakout.number
integer
query
False
Filter by identity.breakout.number
identity.number
integer
query
False
Filter by identity.number
identity.index
integer
query
False
Filter by identity.index
identity.name
string
query
False
Filter by identity.name
vpc_peer_link
boolean
query
False
Filter by vpc_peer_link
  • Introduced in: 9.15
mtu
integer
query
False
Filter by mtu
configured
string
query
False
Filter by configured
isl
boolean
query
False
Filter by isl
duplex_type
string
query
False
Filter by duplex_type
roles.type
string
query
False
Filter by roles.type
roles.dr_group
string
query
False
Filter by roles.dr_group
roles.zone
integer
query
False
Filter by roles.zone
  • Min value: 1
mac_address
string
query
False
Filter by mac_address
speed
integer
query
False
Filter by speed
state
string
query
False
Filter by state
remote_port.functional_roles
string
query
False
Filter by remote_port.functional_roles
remote_port.device.node.name
string
query
False
Filter by remote_port.device.node.name
remote_port.device.node.uuid
string
query
False
Filter by remote_port.device.node.uuid
remote_port.device.discovered_name
string
query
False
Filter by remote_port.device.discovered_name
remote_port.device.dcn.serial_number
string
query
False
Filter by remote_port.device.dcn.serial_number
  • Introduced in: 9.18
remote_port.device.dcn.name
string
query
False
Filter by remote_port.device.dcn.name
remote_port.device.dcn.uuid
string
query
False
Filter by remote_port.device.dcn.uuid
remote_port.device.shelf.name
string
query
False
Filter by remote_port.device.shelf.name
  • Introduced in: 9.12
remote_port.device.shelf.uid
string
query
False
Filter by remote_port.device.shelf.uid
remote_port.device.shelf.module
string
query
False
Filter by remote_port.device.shelf.module
remote_port.mtu
integer
query
False
Filter by remote_port.mtu
remote_port.name
string
query
False
Filter by remote_port.name
statistics.timestamp
string
query
False
Filter by statistics.timestamp
statistics.transmit_raw.discards
integer
query
False
Filter by statistics.transmit_raw.discards
statistics.transmit_raw.errors
integer
query
False
Filter by statistics.transmit_raw.errors
statistics.transmit_raw.packets
integer
query
False
Filter by statistics.transmit_raw.packets
statistics.receive_raw.discards
integer
query
False
Filter by statistics.receive_raw.discards
statistics.receive_raw.errors
integer
query
False
Filter by statistics.receive_raw.errors
statistics.receive_raw.packets
integer
query
False
Filter by statistics.receive_raw.packets
type
string
query
False
Filter by type
vlan_id
integer
query
False
Filter by vlan_id
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Min value: 0
  • Default value: 15
  • Max value: 120
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of Records
records
array[switch_port]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "configured": "string",
      "duplex_type": "string",
      "identity": {
        "breakout": {
          "number": 1,
          "physical_port": "Ethernet1/9"
        "index": 0,
        "name": "string",
        "number": 0
      "mac_address": "string",
      "mtu": 0,
      "remote_port": {
        "device": {
          "dcn": {
            "name": "node1",
            "serial_number": "4048820-60-9",
          "discovered_name": "stiA400-311",
          "node": {
            "name": "node1",
          "shelf": {
            "module": "string",
            "name": "1.1",
            "uid": "12439000444923584512"
        "functional_roles": [
          "string"
        "mtu": 0,
        "name": "string"
      "roles": [
          "dr_group": "string",
          "type": "string"
      "speed": 0,
      "state": "string",
      "statistics": {
        "receive_raw": {
          "discards": 100,
          "errors": 200,
          "packets": 500
        "timestamp": "2024-11-18 15:52:17 +0000",
        "transmit_raw": {
          "discards": 100,
          "errors": 200,
          "packets": 500
      "switch": {
        "name": "RTP-SS01-510R03(FOC223443KQ)"
      "type": "string",
      "vlan_id": [
        "integer"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
breakout
number
integer
Breakout port sub-interface number.
physical_port
string
Breakout physical port name.
identity
breakout
breakout
index
integer
Interface Index.
name
string
Interface Name.
number
integer
Interface Number.
self
dcn
Compute node connected to this port.
_links
_links
name
string
Compute node name.
serial_number
string
Compute node serial number.
uuid
string
Compute node UUID.
node
_links
_links
name
string
uuid
string
shelf
Shelf connected to this port.
_links
_links
module
string
Shelf module connected to this port.
name
string
uid
string
device
Device connected to port.
dcn
dcn
discovered_name
string
Raw name of the discovered device.
node
node
shelf
shelf
remote_port
Remote port.
device
device
functional_roles
array[string]
mtu
integer
MTU in octets.
name
string
Remote port name.
roles
Allowed use for this port.
dr_group
string
DR group.
type
string
Allowed use type.
zone
integer
Zone ID to differentiate between roles with the same type.
receive_raw
Packet receive counters for the Ethernet port.
discards
integer
Total number of discarded packets.
errors
integer
Number of packet errors.
packets
integer
Total packet count.
transmit_raw
Packet transmit counters for the Ethernet port.
discards
integer
errors
integer
packets
integer
Total packet count.
statistics
These are raw counters for the device associated with the Ethernet port.
receive_raw
receive_raw
timestamp
string
The time the statistics were gathered.
transmit_raw
transmit_raw
switch
The name of the specified cluster or storage switch.
_links
self_link
name
string
switch_port
Ethernet Switch Port REST API
_links
self_link
configured
string
Administrative Status.
duplex_type
string
Duplex Settings.
identity
identity
isl
boolean
Is configured as an ISL link.
mac_address
string
MAC Address.
mtu
integer
MTU.
remote_port
remote_port
Remote port.
roles
array[roles]
speed
integer
Interface Speed(Mbps).
state
string
Operational Status.
statistics
statistics
switch
switch
type
string
Interface Type.
vlan_id
array[integer]
vpc_peer_link
boolean
Is configured as a Virtual Port Channel (vPC) peer-link.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
