Retrieve an S3 bucket for an SVM
Retrieves the S3 bucket configuration for a Storage Virtual Machine (SVM) to access detailed bucket settings and policy conditions.
HTTP method and endpoint
GET /protocols/s3/services/{svm.uuid}/buckets/{uuid}
Introduced in
ONTAP 9.7
Usage notes
Retrieves the S3 bucket configuration of an SVM. Note that in order to retrieve S3 bucket policy conditions, the 'fields' option should be set to '**'.
Related ONTAP commands
vserver object-store-server bucket show -
vserver object-store-server bucket policy statement show -
vserver object-store-server bucket policy-statement-condition show
uuid |
string |
path |
True |
The unique identifier of the bucket. |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
comment |
string |
Can contain any additional information about the bucket being created or modified. |
encryption |
logical_used_size |
integer |
Specifies the bucket logical used size up to this point. |
name |
string |
Specifies the name of the bucket. Bucket name is a string that can only contain the following combination of ASCII-range alphanumeric characters 0-9, a-z, ".", and "-". |
policy |
A policy is an object associated with a bucket. It defines resource (bucket, folder, or object) permissions. These policies get evaluated when an S3 user makes a request by executing a specific command. The user must be part of the principal (user or group) specified in the policy. Permissions in the policies determine whether the request is allowed or denied. |
qos_policy |
Specifes "qos_policy.max_throughput_iops" and/or "qos_policy.max_throughput_mbps" or "qos_policy.min_throughput_iops". Specifes "min_throughput_iops" is only supported on volumes hosted on a node that is flash optimized. A pre-created QoS policy can also be used by specifying "qos_policy.name" or "qos_policy.uuid" properties. Setting or assigning a QoS policy to a bucket is not supported if its containing volume or SVM already has a QoS policy attached. |
size |
integer |
Specifies the bucket size in bytes; ranges from 80MB to 64TB. |
svm |
uuid |
string |
Specifies the unique identifier of the bucket. |
volume |
Specifies the FlexGroup volume name and UUID where the bucket is hosted. |
"comment": "S3 bucket.",
"logical_used_size": 0,
"name": "bucket1",
"policy": {
"statements": [
"actions": [
"GetObject",
"PutObject",
"DeleteObject",
"ListBucket"
"conditions": [
"delimiters": [
"max_keys": [
"1000"
"operator": "ip_address",
"prefixes": [
"pref"
"source_ips": [
"1.1.1.1",
"1.2.2.0/24"
"usernames": [
"user1"
"effect": "allow",
"principals": [
"user1",
"group/grp1"
"resources": [
"bucket1",
"bucket1/*"
"sid": "FullAccessToUser1"
"qos_policy": {
"href": "/api/resourcelink"
"max_throughput_iops": "10000",
"max_throughput_mbps": "500",
"min_throughput_iops": "2000",
"min_throughput_mbps": "500",
"name": "performance",
"size": "1677721600",
"svm": {
"name": "svm1",
"uuid": "414b29a1-3b26-11e9-bd58-0050568ea055",
"volume": {
"name": "volume1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
aggregates
Aggregate
_links |
name |
string |
uuid |
string |
encryption
enabled |
boolean |
Specifies whether encryption is enabled on the bucket. By default, encryption is disabled on a bucket. |
s3_bucket_policy_condition
Information about policy conditions based on various condition operators and condition keys.
delimiters |
array[string] |
An array of delimiters that are compared with the delimiter value specified at the time of execution of an S3-based command, using the condition operator specified. |
max_keys |
array[integer] |
An array of maximum keys that are allowed or denied to be retrieved using an S3 list operation, based on the condition operator specified. |
operator |
string |
Condition operator that is applied to the specified condition key. |
prefixes |
array[string] |
An array of prefixes that are compared with the input prefix value specified at the time of execution of an S3-based command, using the condition operator specified. |
source_ips |
array[string] |
An array of IP address ranges that are compared with the IP address of a source command at the time of execution of an S3-based command, using the condition operator specified. |
usernames |
array[string] |
An array of usernames that a current user in the context is evaluated against using the condition operators. |
s3_bucket_policy_statement
Specifies information about a single access permission.
actions |
array[string] |
conditions |
array[s3_bucket_policy_condition] |
Specifies bucket policy conditions. |
effect |
string |
Specifies whether access is allowed or denied when a user requests the specific action. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access. |
principals |
array[string] |
resources |
array[string] |
sid |
string |
Specifies the statement identifier used to differentiate between statements. |
policy
statements |
array[s3_bucket_policy_statement] |
Specifies bucket access policy statement. |
qos_policy
_links |
max_throughput_iops |
integer |
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
max_throughput_mbps |
integer |
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
min_throughput_iops |
integer |
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. |
min_throughput_mbps |
integer |
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
name |
string |
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH. |
uuid |
string |
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
