REST API reference
Retrieve an S3 bucket for an SVM
Retrieves the S3 bucket configuration for a Storage Virtual Machine (SVM) to understand its setup and manage access policies.
HTTP method and endpoint
GET /protocols/s3/services/{svm.uuid}/buckets/{uuid}
Introduced in
ONTAP 9.7
Usage notes
Retrieves the S3 bucket configuration of an SVM. Note that in order to retrieve S3 bucket policy conditions, the 'fields' option should be set to '**'.
  • vserver object-store-server bucket show
  • vserver object-store-server bucket policy statement show
  • vserver object-store-server bucket policy-statement-condition show
  • vserver object-store-server bucket lifecycle-management-rule show
uuid
string
path
True
The unique identifier of the bucket.
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
audit_event_selector
Event selector allows you to specify access and permission types to audit.
comment
string
Can contain any additional information about the bucket being created or modified.
encryption
encryption
lifecycle_management
Lifecycle management is implemented as an object associated with a bucket. It defines rules to be applied against objects within a bucket. These rules are applied in the background and can delete objects.
logical_used_size
integer
Specifies the bucket logical used size up to this point. This field cannot be set using the PATCH method.
name
string
Specifies the name of the bucket. Bucket name is a string that can only contain the following combination of ASCII-range alphanumeric characters 0-9, a-z, ".", and "-".
nas_path
string
Specifies the NAS path to which the nas bucket corresponds to.
policy
policy
A policy is an object associated with a bucket. It defines resource (bucket, folder, or object) permissions. These policies get evaluated when an S3 user makes a request by executing a specific command. The user must be part of the principal (user or group) specified in the policy. Permissions in the policies determine whether the request is allowed or denied.
protection_status
protection_status
Specifies attributes of bucket protection.
qos_policy
qos_policy
Specifes "qos_policy.max_throughput_iops" and/or "qos_policy.max_throughput_mbps" or "qos_policy.min_throughput_iops" and/or "qos_policy.min_throughput_mbps". Specifying "min_throughput_iops" or "min_throughput_mbps" is only supported on volumes hosted on a node that is flash optimized. A pre-created QoS policy can also be used by specifying "qos_policy.name" or "qos_policy.uuid" properties. Setting or assigning a QoS policy to a bucket is not supported if its containing volume or SVM already has a QoS policy attached.
retention
retention
Specifies the retention mode and default retention period configured on the bucket.
role
string
Specifies the role of the bucket. This field cannot be set in a POST method.
size
integer
Specifies the bucket size in bytes; ranges from 190MB to 62PB.
svm
svm
type
string
Specifies the bucket type. Valid values are "s3"and "nas". This field cannot be set using the PATCH method.
uuid
string
Specifies the unique identifier of the bucket. This field cannot be specified in a POST or PATCH method.
versioning_state
string
Specifies the versioning state of the bucket. Valid values are "disabled", "enabled" or "suspended". Note that the versioning state cannot be modified to 'disabled' from any other state.
volume
volume
Specifies the FlexGroup volume name and UUID where the bucket is hosted. This field cannot be set in a POST method.
  "audit_event_selector": {
    "access": "string",
    "permission": "string"
  "comment": "S3 bucket.",
  "lifecycle_management": {
    "rules": [
            "href": "/api/resourcelink"
        "abort_incomplete_multipart_upload": {
        "bucket_name": "bucket1",
        "expiration": {
          "object_expiry_date": "string"
        "name": "string",
        "non_current_version_expiration": {
        "object_filter": {
          "prefix": "/logs",
          "size_greater_than": 10240,
          "size_less_than": 10485760,
          "tags": [
            "project1=projA",
            "project2=projB"
        "svm": {
          "name": "svm1",
        "uuid": "414b29a1-3b26-11e9-bd58-0050568ea055"
  "logical_used_size": 0,
  "name": "bucket1",
  "nas_path": "/",
  "policy": {
    "statements": [
        "actions": [
          "GetObject",
          "PutObject",
          "DeleteObject",
          "ListBucket"
        "conditions": [
            "delimiters": [
            "max_keys": [
              1000
            "operator": "ip_address",
            "prefixes": [
              "pref"
            "source_ips": [
              "1.1.1.1",
              "1.2.2.0/24"
            "usernames": [
              "user1"
        "effect": "allow",
        "principals": [
          "user1",
          "group/grp1",
          "nasgroup/group1"
        "resources": [
          "bucket1",
          "bucket1/*"
        "sid": "FullAccessToUser1"
  "qos_policy": {
    "max_throughput_iops": 10000,
    "max_throughput_mbps": 500,
    "min_throughput_iops": 2000,
    "min_throughput_mbps": 500,
    "name": "performance",
  "retention": {
    "default_period": "P10Y",
    "mode": "governance"
  "role": "string",
  "size": 819200000,
  "svm": {
    "name": "svm1",
  "type": "s3",
  "uuid": "string",
  "versioning_state": "enabled",
  "volume": {
    "name": "volume1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
aggregates
Aggregate
_links
_links
name
string
uuid
string
access
string
Specifies read and write access types.
permission
string
Specifies allow and deny permission types.
encryption
enabled
boolean
Specifies whether encryption is enabled on the bucket. By default, encryption is disabled on a bucket. This field cannot be set in a POST or PATCH method.
Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket. It cannot be specified with tags.
_links
_links
after_initiation_days
integer
Number of days of initiation after which uploads can be aborted.
expiration
Specifies a way to perform expiration action on filtered objects within a bucket.
_links
_links
expired_object_delete_marker
boolean
Cleanup object delete markers.
object_age_days
integer
Number of days since creation after which objects can be deleted. This cannot be used along with object_expiry_date.
object_expiry_date
string
Specific date from when objects can expire. This cannot be used with object_age_days.
Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket.
_links
_links
new_non_current_versions
integer
Number of latest non-current versions to be retained.
non_current_days
integer
Number of days after which non-current versions can be deleted.
object_filter
Specifies a way to filter objects within a bucket.
_links
_links
prefix
string
A prefix that is matched against object-names within a bucket.
size_greater_than
integer
Size of the object greater than specified for which the corresponding lifecycle rule is to be applied.
size_less_than
integer
Size of the object smaller than specified for which the corresponding lifecycle rule is to be applied.
tags
array[string]
An array of key-value paired tags of the form or <tag=value>.
svm
Specifies the name of the SVM where this bucket exists.
_links
_links
name
string
uuid
string
rules
Information about the lifecycle management rule of a bucket.
_links
_links
bucket_name
string
enabled
boolean
Specifies whether or not the associated rule is enabled.
expiration
expiration
name
string
Bucket lifecycle management rule identifier. The length of the name can range from 0 to 256 characters.
object_filter
object_filter
svm
svm
uuid
string
rules
array[rules]
Specifies an object store lifecycle management policy. This field cannot be set using the PATCH method.
s3_bucket_policy_condition
Information about policy conditions based on various condition operators and condition keys.
delimiters
array[string]
An array of delimiters that are compared with the delimiter value specified at the time of execution of an S3-based command, using the condition operator specified.
max_keys
array[integer]
An array of maximum keys that are allowed or denied to be retrieved using an S3 list operation, based on the condition operator specified.
operator
string
Condition operator that is applied to the specified condition key.
prefixes
array[string]
An array of prefixes that are compared with the input prefix value specified at the time of execution of an S3-based command, using the condition operator specified.
source_ips
array[string]
An array of IP address ranges that are compared with the IP address of a source command at the time of execution of an S3-based command, using the condition operator specified.
usernames
array[string]
An array of usernames that a current user in the context is evaluated against using the condition operators.
s3_bucket_policy_statement
Specifies information about a single access permission.
actions
array[string]
conditions
array[s3_bucket_policy_condition]
Specifies bucket policy conditions.
effect
string
Specifies whether access is allowed or denied when a user requests the specific action. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access.
principals
array[string]
resources
array[string]
sid
string
Specifies the statement identifier used to differentiate between statements. The sid length can range from 1 to 256 characters and can only contain the following combination of characters 0-9, A-Z, and a-z. Special characters are not valid.
policy
statements
array[s3_bucket_policy_statement]
Specifies bucket access policy statement.
destination
is_cloud
boolean
Specifies whether a bucket is protected within the Cloud.
is_external_cloud
boolean
Specifies whether a bucket is protected on external Cloud providers.
is_ontap
boolean
Specifies whether a bucket is protected within ONTAP.
  • Default value: 1
  • readOnly: 1
  • Introduced in: 9.10
  • x-nullable: true
protection_status
destination
destination
is_protected
boolean
Specifies whether a bucket is a source and if it is protected within ONTAP and/or an external cloud. This field cannot be set in a POST method.
  • Default value: 1
  • readOnly: 1
  • x-nullable: true
qos_policy
_links
_links
max_throughput_iops
integer
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
max_throughput_mbps
integer
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_iops
integer
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_mbps
integer
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
retention
default_period
string
Specifies the default retention period that is applied to objects while committing them to the WORM state without an associated retention period. The retention period can be in years, or days. The retention period value represents a duration and must be specified in the ISO-8601 duration format. A period specified for years and days is represented in the ISO-8601 format as "PY" and "PD" respectively, for example "P10Y" represents a duration of 10 years. The period string must contain only a single time element that is, either years, or days. A duration which combines different periods is not supported, for example "P1Y10D" is not supported.
mode
string
The lock mode of the bucket. compliance ‐ A SnapLock Compliance (SLC) bucket provides the highest level of WORM protection and an administrator cannot destroy a compliance bucket if it contains unexpired WORM objects. governance ‐ An administrator can delete a Governance bucket. no_lock ‐ Indicates the bucket does not support object locking.
svm
_links
_links
name
string
uuid
string
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a POST or PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
