Retrieve an S3 bucket for an SVM
GET /protocols/s3/services/{svm.uuid}/buckets/{uuid}
Retrieves the S3 bucket configuration of an SVM.
Related ONTAP commands
vserver object-store-server bucket show
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
uuid |
string |
path |
True |
The unique identifier of the bucket. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
comment |
string |
Can contain any additional information about the bucket being created or modified. |
encryption |
logical_used_size |
integer |
Specifies the bucket logical used size up to this point. |
name |
string |
Specifies the name of the bucket. Bucket name is a string that can only contain the following combination of ASCII-range alphanumeric characters 0-9, a-z, ".", and "-". |
size |
integer |
Specifies the bucket size in bytes; ranges from 80MB to 64TB. |
svm |
uuid |
string |
Specifies the unique identifier of the bucket. |
volume |
Specifies the FlexGroup volume name and UUID where the bucket is hosted. |
"comment": "S3 bucket.",
"logical_used_size": 0,
"name": "bucket-1",
"size": 1677721600,
"svm": {
"href": "/api/resourcelink"
"name": "svm1",
"uuid": "414b29a1-3b26-11e9-bd58-0050568ea055",
"volume": {
"name": "volume1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
aggregates
Aggregate
_links |
name |
string |
uuid |
string |
encryption
enabled |
boolean |
Specifies whether encryption is enabled on the bucket. By default, encryption is disabled on a bucket. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
