Retrieve the Vscan configuration for an SVM
Retrieves the Vscan configuration for a specified SVM, which includes details about scanner-pools, On-Access policies, On-Demand policies, and the Vscan enablement status. Use this endpoint to understand and verify the current Vscan setup on your SVM.
HTTP method and endpoint
GET /protocols/vscan/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
This includes scanner-pools, On-Access policies, On-Demand policies, and information about whether a Vscan is enabled or disabled on an SVM.
Important note:
You can enable only one Vscan configuration at a time for an SVM.
Related ONTAP commands
vserver vscan show -
vserver vscan scanner-pool show -
vserver vscan scanner-pool servers show -
vserver vscan scanner-pool privileged-users show -
vserver vscan on-access-policy show -
vserver vscan on-access-policy file-ext-to-exclude show -
vserver vscan on-access-policy file-ext-to-include show -
vserver vscan on-access-policy paths-to-exclude show -
vserver vscan on-demand-task show
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
cache_clear |
boolean |
Discards the cached information of the files that have been successfully scanned. Once the cache is cleared, files are scanned again when they are accessed. PATCH only |
enabled |
boolean |
Specifies whether or not Vscan is enabled on the SVM. |
on_access_policies |
array[vscan_on_access] |
on_demand_policies |
array[vscan_on_demand] |
scanner_pools |
array[vscan_scanner_pool] |
svm |
"href": "/api/resourcelink"
"on_access_policies": [
"name": "on-access-test",
"scope": {
"exclude_extensions": [
"mp*",
"txt"
"exclude_paths": [
"\\dir1\\dir2\\name",
"\\vol\\a b",
"\\vol\\a,b\\"
"include_extensions": [
"mp*",
"txt"
"max_file_size": "2147483648"
"on_demand_policies": [
"log_path": "/vol0/report_dir",
"name": "task-1",
"scan_paths": [
"/vol1/",
"/vol2/cifs/"
"schedule": {
"name": "weekly",
"scope": {
"mp3",
"mp4"
"exclude_paths": [
"/vol1/cold-files/",
"/vol1/cifs/names"
"vmdk",
"mp*"
"max_file_size": "10737418240"
"scanner_pools": [
"cluster": {
"name": "cluster1",
"name": "scanner-1",
"privileged_users": [
"cifs\\u1",
"cifs\\u2"
"role": "string",
"servers": [
"1.1.1.1",
"10.72.204.27",
"vmwin204-27.fsct.nb"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
scope
exclude_extensions |
array[string] |
List of file extensions for which scanning is not performed. |
exclude_paths |
array[string] |
List of file paths for which scanning must not be performed. |
include_extensions |
array[string] |
List of file extensions to be scanned. |
max_file_size |
integer |
Maximum file size, in bytes, allowed for scanning. |
only_execute_access |
boolean |
Scan only files opened with execute-access. |
scan_readonly_volumes |
boolean |
Specifies whether or not read-only volume can be scanned. |
scan_without_extension |
boolean |
Specifies whether or not files without any extension can be scanned. |
vscan_on_access
An On-Access policy that defines the scope of an On-Access scan. Use On-Access scanning to check for viruses when clients open, read, rename, or close files over CIFS. By default, ONTAP creates an On-Access policy named "default_CIFS" and enables it for all the SVMs in a cluster.
enabled |
boolean |
Status of the On-Access Vscan policy |
mandatory |
boolean |
Specifies if scanning is mandatory. File access is denied if there are no external virus-scanning servers available for virus scanning. |
name |
string |
On-Access policy ame |
scope |
schedule
Schedule of the task.
_links |
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
scope
array[string] |
exclude_paths |
array[string] |
array[string] |
max_file_size |
integer |
boolean |
vscan_on_demand
Use On-Demand scanning to check files for viruses on a schedule. An On-Demand policy defines the scope of an On-Demand scan.
log_path |
string |
The path from the Vserver root where the task report is created. |
name |
string |
On-Demand task name |
scan_paths |
array[string] |
List of paths that need to be scanned. |
schedule |
Schedule of the task. |
scope |
cluster_reference
_links |
name |
string |
uuid |
string |
vscan_scanner_pool
Scanner pool is a set of attributes which are used to validate and manage connections between clustered ONTAP and external virus-scanning server, or "Vscan server".
cluster |
name |
string |
Specifies the name of the scanner pool. Scanner pool name can be up to 256 characters long and is a string that can only contain any combination of ASCII-range alphanumeric characters a-z, A-Z, 0-9), "_", "-" and ".". |
privileged_users |
array[string] |
Specifies a list of privileged users. A valid form of privileged user-name is "domain-name\user-name". Privileged user-names are stored and treated as case-insensitive strings. Virus scanners must use one of the registered privileged users for connecting to clustered Data ONTAP for exchanging virus-scanning protocol messages and to access file for scanning, remedying and quarantining operations.
role |
string |
Specifies the role of the scanner pool. The possible values are:
servers |
array[string] |
Specifies a list of IP addresses or FQDN for each Vscan server host names which are allowed to connect to clustered ONTAP.
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
