Retrieve the Vscan configuration for an SVM
GET /protocols/vscan/{svm.uuid}
Introduced In: 9.6
Retrieves the Vscan configuration for a specified SVM. This includes scanner-pools, On-Access policies, On-Demand policies, and information about whether a Vscan is enabled or disabled on an SVM.
Important note:
You can enable only one Vscan configuration at a time for an SVM.
Related ONTAP commands
vserver vscan show -
vserver vscan scanner-pool show -
vserver vscan scanner-pool servers show -
vserver vscan scanner-pool privileged-users show -
vserver vscan on-access-policy show -
vserver vscan on-access-policy file-ext-to-exclude show -
vserver vscan on-access-policy file-ext-to-include show -
vserver vscan on-access-policy paths-to-exclude show -
vserver vscan on-demand-task show
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
cache_clear  |
boolean  |
Discards the cached information of the files that have been successfully scanned. Once the cache is cleared, files are scanned again when they are accessed. PATCH only  |
enabled  |
boolean  |
Specifies whether or not Vscan is enabled on the SVM.  |
on_access_policies  |
array[vscan_on_access]  |
on_demand_policies  |
array[vscan_on_demand_policy]  |
scanner_pools  |
array[scanner_pool]  |
svm  |
      "href": "/api/resourcelink"
  "on_access_policies": [
      "name": "on-access-test",
      "scope": {
        "exclude_extensions": [
          "mp*",
          "txt"
        "exclude_paths": [
          "\\dir1\\dir2\\name",
          "\\vol\\a b",
          "\\vol\\a,b\\"
        "include_extensions": [
          "mp*",
          "txt"
        "max_file_size": 2147483648
  "on_demand_policies": [
      "log_path": "/vol0/report_dir",
      "name": "task-1",
      "scan_paths": [
        "/vol1/",
        "/vol2/cifs/"
      "schedule": {
        "name": "weekly",
      "scope": {
          "mp3",
          "mp4"
        "exclude_paths": [
          "/vol1/cold-files/",
          "/vol1/cifs/names"
          "vmdk",
          "mp*"
        "max_file_size": 10737418240
  "scanner_pools": [
      "cluster": {
        "name": "cluster1",
      "name": "scanner-1",
      "privileged_users": [
        "cifs\\u1",
        "cifs\\u2"
      "role": "string",
      "servers": [
        "1.1.1.1",
        "10.72.204.27",
        "vmwin204-27.fsct.nb"
  "svm": {
    "name": "svm1",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
scope
exclude_extensions  |
array[string]  |
List of file extensions for which scanning is not performed.  |
exclude_paths  |
array[string]  |
List of file paths for which scanning must not be performed.  |
include_extensions  |
array[string]  |
List of file extensions to be scanned.  |
max_file_size  |
integer  |
Maximum file size, in bytes, allowed for scanning.  |
only_execute_access  |
boolean  |
Scan only files opened with execute-access.  |
scan_readonly_volumes  |
boolean  |
Specifies whether or not read-only volume can be scanned.  |
scan_without_extension  |
boolean  |
Specifies whether or not files without any extension can be scanned.  |
vscan_on_access
An On-Access policy that defines the scope of an On-Access scan. Use On-Access scanning to check for viruses when clients open, read, rename, or close files over CIFS. By default, ONTAP creates an On-Access policy named "default_CIFS" and enables it for all the SVMs in a cluster.
enabled  |
boolean  |
Status of the On-Access Vscan policy  |
mandatory  |
boolean  |
Specifies if scanning is mandatory. File access is denied if there are no external virus-scanning servers available for virus scanning.  |
name  |
string  |
On-Access policy ame  |
scope  |
schedule
Schedule of the task.
_links  |
name  |
string  |
Job schedule name  |
uuid  |
string  |
Job schedule UUID  |
scope
array[string]  |
exclude_paths  |
array[string]  |
array[string]  |
max_file_size  |
integer  |
boolean  |
Use On-Demand scanning to check files for viruses on a schedule. An On-Demand policy defines the scope of an On-Demand scan.
log_path  |
string  |
The path from the Vserver root where the task report is created.  |
name  |
string  |
On-Demand task name  |
scan_paths  |
array[string]  |
List of paths that need to be scanned.  |
schedule  |
Schedule of the task.  |
scope  |
cluster_reference
_links  |
name  |
string  |
uuid  |
string  |
scanner_pool
Scanner pool is a set of attributes which are used to validate and manage connections between clustered ONTAP and external virus-scanning server, or "Vscan server".
cluster  |
name  |
string  |
Specifies the name of the scanner pool. Scanner pool name can be up to 256 characters long and is a string that can only contain any combination of ASCII-range alphanumeric characters a-z, A-Z, 0-9), "_", "-" and ".".  |
privileged_users  |
array[string]  |
Specifies a list of privileged users. A valid form of privileged user-name is "domain-name\user-name". Privileged user-names are stored and treated as case-insensitive strings. Virus scanners must use one of the registered privileged users for connecting to clustered Data ONTAP for exchanging virus-scanning protocol messages and to access file for scanning, remedying and quarantining operations.
role  |
string  |
Specifies the role of the scanner pool. The possible values are:
servers  |
array[string]  |
Specifies a list of IP addresses or FQDN for each Vscan server host names which are allowed to connect to clustered ONTAP.
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
