Retrieve attributes of an ongoing SnapMirror transfer
GET /snapmirror/relationships/{relationship.uuid}/transfers/{uuid}
Introduced In: 9.6
Retrieves the attributes of a specific ongoing SnapMirror transfer.
Related ONTAP commands
snapmirror show
Example
GET "/api/snapmirror/relationships/293baa53-e63d-11e8-bff1-005056a793dd/transfers/293baa53-e63d-11e8-bff1-005056a793dd"
relationship.uuid  |
string  |
path  |
True  |
Relationship UUID  |
uuid  |
string  |
path  |
True  |
Transfer UUID  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
bytes_transferred  |
integer  |
Bytes transferred  |
checkpoint_size  |
integer  |
Amount of data transferred in bytes as recorded in the restart checkpoint.  |
relationship  |
snapshot  |
string  |
Name of Snapshot copy being transferred.  |
state  |
string  |
Status of the transfer. Set PATCH state to "aborted" to abort the transfer. Set PATCH state to "hard_aborted" to abort the transfer and discard the restart checkpoint.  |
throttle  |
integer  |
Throttle, in KBs per second. This "throttle" overrides the "throttle" set on the SnapMirror relationship or SnapMirror relationship's policy. If neither of these are set, defaults to 0, which is interpreted as unlimited.  |
uuid  |
string  |
      "href": "/api/resourcelink"
  "bytes_transferred": 0,
  "checkpoint_size": 0,
  "relationship": {
    "destination": {
      "cluster": {
        "name": "cluster1",
      "consistency_group_volumes": [
          "name": "volume1",
      "path": "svm1:volume1",
      "svm": {
        "name": "svm1",
    "uuid": "d2d7ceea-ab52-11e8-855e-00505682a4c7"
  "snapshot": "string",
  "state": "string",
  "storage_efficiency_enabled": null,
  "throttle": 0,
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
files
Specifies a file or LUN consisting of a source_path and an optional destination_path. If not specified, the destination_path is the same as the source_path.
destination_path  |
string  |
source_path  |
string  |
cluster
_links  |
name  |
string  |
uuid  |
string  |
_links  |
name  |
string  |
The name of the volume.  |
uuid  |
string  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
snapmirror_endpoint
Endpoint of a SnapMirror relationship. For a GET request, the property "cluster" is populated when the endpoint is on a remote cluster. A POST request to create the destination SVM endpoint or to establish an SVM DR relationship must have the property "cluster" populated with the remote cluster details. A POST request to create the destination FlexVol volume, FlexGroup volume, and Consistency Group endpoints can optionally specify the "cluster" property when the source SVM and the destination SVM are peered. A POST request to establish a SnapMirror relationship between the source endpoint and destination endpoint and when the source SVM and the destination SVM are not peered, must specify the "cluster" property for the remote endpoint.
cluster  |
consistency_group_volumes  |
array[consistency_group_volumes]  |
Mandatory property for a Consistency Group endpoint. Specifies the list of FlexVol volumes for a Consistency Group.  |
path  |
string  |
ONTAP FlexVol/FlexGroup - svm1:volume1 ONTAP SVM - svm1: ONTAP Consistency Group - svm1:/cg/cg_name
svm  |
relationship
destination  |
Endpoint of a SnapMirror relationship. For a GET request, the property "cluster" is populated when the endpoint is on a remote cluster. A POST request to create the destination SVM endpoint or to establish an SVM DR relationship must have the property "cluster" populated with the remote cluster details. A POST request to create the destination FlexVol volume, FlexGroup volume, and Consistency Group endpoints can optionally specify the "cluster" property when the source SVM and the destination SVM are peered. A POST request to establish a SnapMirror relationship between the source endpoint and destination endpoint and when the source SVM and the destination SVM are not peered, must specify the "cluster" property for the remote endpoint.  |
restore  |
boolean  |
Is the relationship for restore?  |
uuid  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
