Retrieve attributes of an ongoing SnapMirror transfer
Retrieves the attributes of a SnapMirror transfer that is currently in progress. This information helps you monitor and manage ongoing data replication activities effectively.
HTTP method and endpoint
GET /snapmirror/relationships/{relationship.uuid}/transfers/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves the attributes of a specific ongoing SnapMirror transfer.
Related ONTAP commands
snapmirror show
Example
GET "/api/snapmirror/relationships/293baa53-e63d-11e8-bff1-005056a793dd/transfers/293baa53-e63d-11e8-bff1-005056a793dd"
relationship.uuid |
string |
path |
True |
Relationship UUID |
uuid |
string |
path |
True |
Transfer UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
bytes_transferred |
integer |
Bytes transferred |
checkpoint_size |
integer |
Amount of data transferred in bytes as recorded in the restart checkpoint. |
end_time |
string |
End time of the transfer. |
error_info |
Error information for the transfer. |
relationship |
snapshot |
string |
Name of Snapshot copy being transferred. |
state |
string |
Status of the transfer. Set PATCH state to "aborted" to abort the transfer. Set PATCH state to "hard_aborted" to abort the transfer and discard the restart checkpoint. |
throttle |
integer |
Throttle in KB/s. Defaults to throttle setting of the associated SnapMirror policy if set, or 0, which is interpreted as unlimited. |
total_duration |
string |
Elapsed transfer time. |
uuid |
string |
"href": "/api/resourcelink"
"bytes_transferred": 0,
"checkpoint_size": 0,
"end_time": "2020-12-02T18:36:19-08:00",
"error_info": {
"code": 6620046,
"message": "Transfer aborted"
"relationship": {
"destination": {
"cluster": {
"name": "cluster1",
"consistency_group_volumes": [
"name": "volume1",
"path": "svm1:volume1",
"svm": {
"name": "svm1",
"uuid": "d2d7ceea-ab52-11e8-855e-00505682a4c7"
"snapshot": "string",
"state": "string",
"storage_efficiency_enabled": null,
"throttle": 0,
"total_duration": "PT28M41S",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
error_info
code |
integer |
Error code |
message |
string |
Error message |
files
Specifies a file or LUN consisting of a source_path and an optional destination_path. If not specified, the destination_path is the same as the source_path. File restore is not supported if the source_path or destination_path contains commas in its directory or file name.
destination_path |
string |
source_path |
string |
cluster
_links |
name |
string |
uuid |
string |
_links |
name |
string |
The name of the volume. |
uuid |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
snapmirror_endpoint
Endpoint of a SnapMirror relationship. For a GET request, the property "cluster" is populated when the endpoint is on a remote cluster. A POST request to create the destination SVM endpoint or to establish an SVM DR relationship must have the property "cluster" populated with the remote cluster details. A POST request to create the destination FlexVol volume, FlexGroup volume, Consistency Group, ONTAP S3 bucket and NON-ONTAP object-store endpoints can optionally specify the "cluster" property when the source SVM and the destination SVM are peered. A POST request to establish a SnapMirror relationship between the source endpoint and destination endpoint and when the source SVM and the destination SVM are not peered, must specify the "cluster" property for the remote endpoint.
cluster |
consistency_group_volumes |
array[consistency_group_volumes] |
Mandatory property for a Consistency Group endpoint. Specifies the list of FlexVol volumes for a Consistency Group. |
path |
string |
ONTAP FlexVol/FlexGroup - svm1:volume1 ONTAP SVM - svm1: ONTAP Consistency Group - svm1:/cg/cg_name ONTAP S3 - svm1:/bucket/bucket1 NON-ONTAP - objstore1:/objstore
svm |
relationship
destination |
restore |
boolean |
Is the relationship for restore? |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
