Retrieve an event destination
Retrieves event destination configurations, which specify where event notifications are sent. Use this endpoint to manage the destinations for system alerts and notifications.
HTTP method and endpoint
GET /support/ems/destinations/{name}
Introduced in
ONTAP 9.6
Usage notes
Retrieves event destinations.
Related ONTAP commands
event notification destination show -
event notification show
name |
string |
path |
True |
Destination name |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
certificate |
Certificate information is valid for the "rest_api" type. |
destination |
string |
Event destination |
filters |
array[filters] |
name |
string |
Destination name. Valid in POST. |
type |
string |
Type of destination. Valid in POST. |
"href": "/api/resourcelink"
"certificate": {
"ca": "VeriSign",
"serial_number": "1234567890"
"destination": "administrator@mycompany.com",
"filters": [
"name": "important-events"
"name": "Admin_Email",
"type": "email"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
certificate
ca |
string |
Client certificate issuing CA |
serial_number |
string |
Client certificate serial number |
filters
_links |
name |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
