REST API reference
Retrieve an event destination
Retrieves event destinations to review or audit existing event notification configurations.
HTTP method and endpoint
GET /support/ems/destinations/{name}
Introduced in
ONTAP 9.6
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter.
  • connectivity.*
  • event notification destination show
  • event notification show
name
string
path
True
Destination name
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
certificate
certificate
Specifies the client-side certificate used by the ONTAP system when mutual authentication is required. This object is only applicable for rest_api type destinations. Both the ca and serial_number fields must be specified when configuring a certificate in a PATCH or POST request. The name field is read-only and cannot be used to configure a client-side certificate.
  • Introduced in: 9.6
connectivity
connectivity
destination
string
Event destination
filters
array[filters]
name
string
Destination name. Valid in POST.
syslog
syslog
system_defined
boolean
Flag indicating system-defined destinations.
type
string
Type of destination. Valid in POST.
      "href": "/api/resourcelink"
  "certificate": {
    "ca": "VeriSign",
    "name": "cert1",
    "serial_number": "1234567890"
  "connectivity": {
    "errors": [
        "message": {
          "arguments": [
              "code": "string",
              "message": "string"
          "code": "4",
          "message": "entry doesn't exist"
        "node": {
          "name": "node1",
    "state": "fail"
  "destination": "administrator@mycompany.com",
  "filters": [
      "name": "important-events"
  "name": "Admin_Email",
  "syslog": {
    "format": {
      "hostname_override": "string",
      "message": "string",
      "timestamp_override": "string"
    "port": 514,
    "transport": "string"
  "system_defined": 1,
  "type": "email"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
certificate
_links
_links
ca
string
Client certificate issuing CA
name
string
Certificate name
serial_number
string
Client certificate serial number
arguments
code
string
Argument code
message
string
Message argument
message
arguments
array[arguments]
Message arguments
code
string
Unique message code.
message
string
User message.
node
_links
_links
name
string
uuid
string
errors
Error object included in the event of connectivity failure.
message
message
node
node
connectivity
errors
array[errors]
A list of errors encountered during connectivity checks.
state
string
Current connectivity state.
filters
_links
_links
name
string
format
hostname_override
string
Syslog Hostname Format Override. The supported hostname formats are no_override (hostname format based on the syslog.format.message property i.e. fqdn if syslog.format.message is rfc_5424, hostname_only if syslog.format.message is legacy_netapp), fqdn (Fully Qualified Domain Name) and hostname_only.
message
string
Syslog Message Format. The supported message formats are legacy_netapp (format: <PRIVAL>TIMESTAMP [HOSTNAME:Event-name:Event-severity]: MSG) and rfc_5424 (format: <PRIVAL>VERSION TIMESTAMP HOSTNAME Event-source - Event-name - MSG).
timestamp_override
string
Syslog Timestamp Format Override. The supported timestamp formats are no_override (timestamp format based on the syslog.format.message property i.e. rfc_3164 if syslog.format.message is legacy_netapp, iso_8601_local_time if syslog.format.message is rfc_5424), rfc_3164 (format: Mmm dd hh:mm:ss), iso_8601_local_time (format: YYYY-MM-DDThh:mm:ss+/-hh:mm) and iso_8601_utc (format: YYYY-MM-DDThh:mm:ssZ).
syslog
format
format
port
integer
Syslog Port.
transport
string
Syslog Transport Protocol.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
