REST API reference
Retrieve an event destination
GET /support/ems/destinations/{name}
Retrieves event destinations.
  • event notification destination show
  • event notification show
name
string
path
True
Destination name
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
certificate
certificate
Certificate information is valid for the "rest_api" type.
destination
string
Event destination
filters
array[filters]
name
string
Destination name. Valid in POST.
type
string
Type of destination. Valid in POST.
      "href": "/api/resourcelink"
  "certificate": {
    "ca": "VeriSign",
    "serial_number": 1234567890
  "destination": "administrator@mycompany.com",
  "filters": [
      "name": "important-events"
  "name": "Admin_Email",
  "type": "email"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
certificate
ca
string
Client certificate issuing CA
serial_number
string
Client certificate serial number
filters
_links
_links
name
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
