Retrieves event destinations
event notification show
learn more
doc /support/ems/destinations/{name}](#docs-support-support_ems_destinations_{name})
GET /support/ems/destinations/{name}
Retrieves event destinations.
Related ONTAP commands
event notification destination show -
Learn more
name |
string |
path |
True |
Destination name |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
certificate |
Certificate information is valid for the "rest_api" type. |
destination |
string |
Event destination |
filters |
array[filters] |
name |
string |
Destination name. Valid in POST. |
type |
string |
Type of destination. Valid in POST. |
"href": "/api/resourcelink"
"certificate": {
"ca": "VeriSign",
"serial_number": 1234567890
"destination": "administrator@mycompany.com",
"filters": [
"name": "important-events"
"name": "Admin_Email",
"type": "email"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
certificate
ca |
string |
Client certificate issuing CA |
serial_number |
string |
Client certificate serial number |
filters
_links |
name |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
