Update application properties
Updates the properties of an application by modifying its template properties, such as storage_service, size, and igroup_name. This allows you to adjust the application's configuration to meet changing performance or capacity requirements.
HTTP method and endpoint
PATCH /application/applications/{uuid}
Introduced in
ONTAP 9.6
Overview
Similar to creating an application, modification is done using the template properties of an application. The storage_service, size, and igroup_name of an application may be modified.
storage_service
Storage service modifications are processed in place, meaning that the storage can not be moved to a location with more performance headroom to accommodate the request. If the current backing storage of the application is in a location that can support increased performance, the QoS policies associated with the application will be modified to allow it. If not, an error will be returned. A storage service modification to a lower tier of performance is always allowed, but the reverse modification may not be supported if the cluster is over provisioned and the cluster is unlikely to be able to fulfil the original storage service.
size
Size modifications are processed in a variety of ways depending on the type of application. For NAS applications, volumes are grown or new volumes are added. For SAN applications, LUNs are grown, new LUNs are added to existing volumes, or new LUNs are added to new volumes. If new storage elements are created, they can be found using the GET /application/applications/{application.uuid}/components interface. The creation time of each storage object is included, and the newly created objects will use the same naming scheme as the previous objects. Resize follows the best practices associated with the type of application being expanded. Reducing the size of an application is not supported.
igroup_name
Modification of the igroup name allows an entire application to be mapped from one initiator group to another. Data access will be interrupted as the LUNs are unmapped from the original igroup and remapped to the new one.
Application state
During a modification, the state property of the application updates to indicate modifying. In modifying state, statistics are not available and Snapshot copy operations are not allowed. If the modification fails, it is possible for the application to be left in an inconsistent state, with the underlying ONTAP storage elements not matching across a component. When this occurs, the application is left in the modifying state until the command is either retried and succeeds or a call to restore the original state is successful.
Change the storage service of the database of the Oracle application to extreme and resize the redo logs to 100GB.
{ "oracle_on_nfs": { "db": { "storage_service": { "name": "extreme" } }, "redo_log": { "size": "100GB" } } } -
Change the storage service, size, and igroup of a generic application by component name.
{ "san": { "application_components": [ { "name": "component1", "storage_service": { "name": "value" } }, { "name": "component2", "size": "200GB" }, { "name": "component3", "igroup_name": "igroup5" } ] } }
Learn more
uuid |
string |
path |
True |
Application UUID |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
_links |
creation_timestamp |
string |
The time when the application was created. |
generation |
integer |
The generation number of the application. This indicates which features are supported on the application. For example, generation 1 applications do not support Snapshot copies. Support for Snapshot copies was added at generation 2. Any future generation numbers and their feature set will be documented. |
maxdata_on_san |
MAX Data application using SAN. |
mongo_db_on_san |
MongoDB using SAN. |
nas |
A generic NAS application. |
nvme |
An NVME application. |
oracle_on_nfs |
Oracle using NFS. |
oracle_on_san |
Oracle using SAN. |
oracle_rac_on_nfs |
Oracle RAC using NFS. |
oracle_rac_on_san |
Oracle RAC using SAN. |
protection_granularity |
string |
Protection granularity determines the scope of Snapshot copy operations for the application. Possible values are "application" and "component". If the value is "application", Snapshot copy operations are performed on the entire application. If the value is "component", Snapshot copy operations are performed separately on the application components. |
rpo |
s3_bucket |
A generic S3 bucket application. |
san |
A generic SAN application. |
sql_on_san |
Microsoft SQL using SAN. |
sql_on_smb |
Microsoft SQL using SMB. |
state |
string |
The state of the application. For full functionality, applications must be in the online state. Other states indicate that the application is in a transient state and not all operations are supported. |
statistics |
template |
uuid |
string |
Application UUID. This field is generated when the application is created. |
vdi_on_nas |
A VDI application using NAS. |
vdi_on_san |
A VDI application using SAN. |
vsi_on_nas |
A VSI application using NAS. |
vsi_on_san |
A VSI application using SAN. |
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default, Error
href |
string |
_links
metadata
protection_type
local_rpo |
string |
The local rpo of the application component. |
remote_rpo |
string |
The remote rpo of the application component. |
storage_service
name |
string |
The storage service of the application component. |
object_stores
maxdata_on_san_application_components_tiering
tiering
The list of application components to be created.
host_management_url |
string |
The host management URL for this application component. |
igroup_name |
string |
The name of the initiator group through which the contents of this application will be accessed. Modification of this parameter is a disruptive operation. All LUNs in the application component will be unmapped from the current igroup and re-mapped to the new igroup. |
lun_count |
integer |
The number of LUNs in the application component. |
name |
string |
The name of the application component. |
protection_type |
storage_service |
tiering |
tiering |
total_size |
integer |
The total size of the application component, split across the member LUNs. Usage: {<integer>[KB|MB|GB|TB|PB]} |
igroups
name |
string |
The name of an igroup to nest within a parent igroup. Mutually exclusive with initiators and initiator_objects. |
uuid |
string |
The UUID of an igroup to nest within a parent igroup Usage: <UUID> |
initiator_objects
comment |
string |
A comment available for use by the administrator. |
name |
string |
The WWPN, IQN, or Alias of the initiator. Mutually exclusive with nested igroups and the initiators array. |
maxdata_on_san_new_igroups
The list of initiator groups to create.
comment |
string |
igroups |
array[igroups] |
initiator_objects |
array[initiator_objects] |
initiators |
array[string] |
name |
string |
The name of the new initiator group. |
os_type |
string |
The name of the host OS accessing the application. The default value is the host OS that is running the application. |
protocol |
string |
The protocol of the new initiator group. |
maxdata_on_san
application_components |
The list of application components to be created. |
new_igroups |
array[maxdata_on_san_new_igroups] |
The list of initiator groups to create. |
ocsm_url |
string |
The OnCommand System Manager URL for this application. |
storage_service
name |
string |
The storage service of the database. |
dataset
size |
integer |
The size of the database. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
mongo_db_on_san_new_igroups
comment |
string |
igroups |
array[igroups] |
initiator_objects |
initiators |
array[string] |
name |
string |
os_type |
string |
protocol |
string |
protection_type
local_rpo |
string |
The local RPO of the application. |
secondary_igroups
name |
string |
The name of the initiator group for each secondary. |
mongo_db_on_san
MongoDB using SAN.
dataset |
new_igroups |
array[mongo_db_on_san_new_igroups] |
primary_igroup_name |
string |
The initiator group for the primary. |
protection_type |
secondary_igroups |
array[secondary_igroups] |
export_policy
component
svm
origin
flexcache
policy
qos
nas_application_components_tiering
application-components.tiering
name |
string |
storage_service |
tiering |
application-components.tiering |
total_size |
integer |
The total size of the application component, split across the member shares. Usage: {<integer>[KB|MB|GB|TB|PB]} |
app_cifs_access
The list of CIFS access controls. You must provide either 'user_or_group' or 'access' to enable CIFS access.
exclude_aggregates
app_nfs_access
The list of NFS access controls. You must provide either 'host' or 'access' to enable NFS access.
nas
array[application_components] |
protection_type |
performance
storage_service |
hosts
nqn |
string |
The host NQN. |
zapp_nvme_components_subsystem
components.subsystem
hosts |
array[hosts] |
name |
string |
The name of the subsystem accessing the component. If neither the name nor the UUID is provided, the name defaults to <application-name>_<component-name>, whether that subsystem already exists or not. |
os_type |
string |
The name of the host OS accessing the component. The default value is the host OS that is running the application. |
uuid |
string |
The UUID of an existing subsystem to be granted access to the component. Usage: <UUID> |
zapp_nvme_components_tiering
components
name |
string |
namespace_count |
integer |
The number of namespaces in the component. |
os_type |
string |
The name of the host OS running the application. |
performance |
subsystem |
components.subsystem |
tiering |
total_size |
integer |
The total size of the component, spread across member namespaces. Usage: {<integer>[KB|MB|GB|TB|PB]} |
local
name |
string |
rpo
local |
zapp_nvme
components |
array[components] |
rpo |
storage_service
name |
string |
The storage service of the archive log. |
archive_log
size |
integer |
The size of the archive log. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
db
size |
integer |
storage_service |
storage_service
name |
string |
The storage service of the ORACLE_HOME storage volume. |
ora_home
size |
integer |
The size of the ORACLE_HOME storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
storage_service
name |
string |
The storage service of the redo log group. |
redo_log
size |
integer |
The size of the redo log group. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
oracle_on_nfs
Oracle using NFS.
archive_log |
db |
ora_home |
protection_type |
redo_log |
oracle_on_san_new_igroups
comment |
string |
igroups |
array[igroups] |
initiator_objects |
initiators |
array[string] |
name |
string |
os_type |
string |
protocol |
string |
oracle_on_san
Oracle using SAN.
archive_log |
db |
igroup_name |
string |
new_igroups |
array[oracle_on_san_new_igroups] |
ora_home |
protection_type |
redo_log |
storage_service
name |
string |
The storage service of the Oracle grid binary storage volume. |
grid_binary
size |
integer |
The size of the Oracle grid binary storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
storage_service
name |
string |
The storage service of the Oracle CRS volume. |
oracle_crs
storage_service |
oracle_rac_on_nfs
archive_log |
db |
grid_binary |
ora_home |
oracle_crs |
protection_type |
redo_log |
db_sids
igroup_name |
string |
oracle_rac_on_san_new_igroups
comment |
string |
igroups |
array[igroups] |
initiator_objects |
initiators |
array[string] |
name |
string |
os_type |
string |
protocol |
string |
oracle_rac_on_san
archive_log |
db |
db_sids |
array[db_sids] |
grid_binary |
new_igroups |
ora_home |
oracle_crs |
protection_type |
redo_log |
local
description |
string |
A detailed description of the local RPO. This will include details about the Snapshot copy schedule. |
name |
string |
The local RPO of the component. This indicates how often component Snapshot copies are automatically created. |
remote
description |
string |
A detailed description of the remote RPO. |
name |
string |
The remote RPO of the component. A remote RPO of zero indicates that the component is synchronously replicated to another cluster. |
rpo
local |
remote |
components
name |
string |
Component Name. |
rpo |
uuid |
string |
Component UUID. |
local
description |
string |
name |
string |
The local RPO of the application. This indicates how often application Snapshot copies are automatically created. |
remote
description |
string |
name |
string |
The remote RPO of the application. A remote RPO of zero indicates that the application is synchronously replicated to another cluster. |
rpo
components |
array[components] |
is_supported |
boolean |
Is RPO supported for this application? Generation 1 applications did not support Snapshot copies or MetroCluster. |
local |
remote |
zapp_s3_bucket_application_components_access_policies_conditions
conditions
delimiters |
array[string] |
max_keys |
array[integer] |
prefixes |
array[string] |
source_ips |
array[string] |
usernames |
array[string] |
The list of S3 objectstore policies to be created.
actions |
array[string] |
principals |
array[string] |
resources |
array[string] |
name |
string |
size |
integer |
The total size of the S3 Bucket, split across the member components. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
uuid |
string |
Object Store Server Bucket UUID Usage: <UUID> |
zapp_s3_bucket
igroup_name |
string |
lun_count |
integer |
name |
string |
os_type |
string |
storage_service |
tiering |
total_size |
integer |
san_new_igroups
comment |
string |
igroups |
array[igroups] |
initiator_objects |
initiators |
array[string] |
name |
string |
os_type |
string |
protocol |
string |
san
new_igroups |
array[san_new_igroups] |
protection_type |
storage_service
name |
string |
The storage service of the DB. |
db
size |
integer |
The size of the DB. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
storage_service
name |
string |
The storage service of the log DB. |
log
size |
integer |
The size of the log DB. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
sql_on_san_new_igroups
comment |
string |
igroups |
array[igroups] |
initiator_objects |
initiators |
array[string] |
name |
string |
os_type |
string |
protocol |
string |
storage_service
name |
string |
The storage service of the temp DB. |
temp_db
size |
integer |
The size of the temp DB. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
sql_on_san
db |
igroup_name |
string |
log |
new_igroups |
array[sql_on_san_new_igroups] |
protection_type |
temp_db |
access
sql_on_smb
db |
log |
protection_type |
temp_db |
iops
per_tb |
integer |
The number of IOPS per terabyte of logical space currently being used by the application component. |
total |
integer |
The total number of IOPS being used by the application component. |
latency
average |
integer |
The cumulative average response time in microseconds for this component. |
raw |
integer |
The cumulative response time in microseconds for this component. |
snapshot
reserve |
integer |
The amount of space reserved by the system for Snapshot copies. |
used |
integer |
The amount of spacing currently in use by the system to store Snapshot copies. |
space
available |
integer |
The available amount of space left in the application component. Note that this field has limited meaning for SAN applications. Space may be considered used from ONTAP's perspective while the host filesystem still considers it available.
logical_used |
integer |
The amount of space that would currently be used if no space saving features were enabled. For example, if compression were the only space saving feature enabled, this field would represent the uncompressed amount of space used. |
provisioned |
integer |
The originally requested amount of space that was provisioned for the application component. |
reserved_unused |
integer |
The amount of space reserved for system features such as Snapshot copies that has not yet been used. |
savings |
integer |
The amount of space saved by all enabled space saving features. |
used |
integer |
The amount of space that is currently being used by the application component. Note that this includes any space reserved by the system for features such as Snapshot copies. |
used_excluding_reserves |
integer |
The amount of space that is currently being used, excluding any space that is reserved by the system for features such as Snapshot copies. |
used_percent |
integer |
The percentage of the originally provisioned space that is currently being used by the application component. |
storage_service
name |
string |
The storage service name. AFF systems support the extreme storage service. All other systems only support value. |
uuid |
string |
The storage service UUID. |
components
iops |
latency |
name |
string |
Component Name. |
shared_storage_pool |
boolean |
An application component is considered to use a shared storage pool if storage elements for for other components reside on the same aggregate as storage elements for this component. |
snapshot |
space |
statistics_incomplete |
boolean |
If not all storage elements of the application component are currently available, the returned statistics might only include data from those elements that were available. |
storage_service |
uuid |
string |
Component UUID. |
iops
per_tb |
integer |
The number of IOPS per terabyte of logical space currently being used by the application. |
total |
integer |
The total number of IOPS being used by the application. |
latency
average |
integer |
The cumulative average response time in microseconds for this application. |
raw |
integer |
The cumulative response time in microseconds for this application. |
space
available |
integer |
The available amount of space left in the application. Note that this field has limited meaning for SAN applications. Space may be considered used from ONTAP's perspective while the host filesystem still considers it available.
logical_used |
integer |
provisioned |
integer |
The originally requested amount of space that was provisioned for the application. |
reserved_unused |
integer |
savings |
integer |
used |
integer |
The amount of space that is currently being used by the application. Note that this includes any space reserved by the system for features such as Snapshot copies. |
integer |
used_percent |
integer |
The percentage of the originally provisioned space that is currently being used by the application. |
statistics
components |
array[components] |
iops |
latency |
boolean |
An application is considered to use a shared storage pool if storage elements for multiple components reside on the same aggregate. |
snapshot |
space |
boolean |
If not all storage elements of the application are currently available, the returned statistics might only include data from those elements that were available. |
self_link
template
protocol |
string |
The protocol access of the template that was used to provision this application. |
version |
integer |
The version of the template that was used to provision this application. The template version changes only if the layout of the application changes over time. For example, redo logs in Oracle RAC templates were updated and provisioned differently in DATA ONTAP 9.3.0 compared to prior releases, so the version number was increased. If layouts change in the future, the changes will be documented along with the corresponding version numbers.
storage_service
name |
string |
The storage service of the desktops. |
desktops
count |
integer |
The number of desktops to support. |
storage_service |
hyper_v_access
vdi_on_nas
desktops |
protection_type |
vdi_on_san_new_igroups
comment |
string |
igroups |
array[igroups] |
initiator_objects |
initiators |
array[string] |
name |
string |
protocol |
string |
vdi_on_san
desktops |
igroup_name |
string |
new_igroups |
array[vdi_on_san_new_igroups] |
protection_type |
storage_service
name |
string |
The storage service of the datastore. |
datastore
count |
integer |
The number of datastores to support. |
storage_service |
vsi_on_nas
datastore |
protection_type |
vsi_on_san_new_igroups
comment |
string |
igroups |
array[igroups] |
initiator_objects |
initiators |
array[string] |
name |
string |
protocol |
string |
vsi_on_san
datastore |
igroup_name |
string |
new_igroups |
array[vsi_on_san_new_igroups] |
protection_type |
application
Applications
_links |
string |
generation |
integer |
maxdata_on_san |
mongo_db_on_san |
nas |
nvme |
oracle_on_nfs |
Oracle using NFS. |
oracle_on_san |
Oracle using SAN. |
oracle_rac_on_nfs |
oracle_rac_on_san |
string |
rpo |
s3_bucket |
san |
sql_on_san |
sql_on_smb |
state |
string |
statistics |
template |
uuid |
string |
vdi_on_nas |
vdi_on_san |
vsi_on_nas |
vsi_on_san |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
