REST API reference
Update application properties
Updates the properties of an application, such as its storage service, size, and igroup name. Use this endpoint to adjust application configurations based on your performance and access needs.
HTTP method and endpoint
PATCH /application/applications/{uuid}
Introduced in
ONTAP 9.6
Overview
Similar to creating an application, modification is done using the template properties of an application. The storage_service, size, and igroup_name of an application may be modified.
storage_service
Storage service modifications are processed in place, meaning that the storage can not be moved to a location with more performance headroom to accommodate the request. If the current backing storage of the application is in a location that can support increased performance, the QoS policies associated with the application will be modified to allow it. If not, an error will be returned. A storage service modification to a lower tier of performance is always allowed, but the reverse modification may not be supported if the cluster is over provisioned and the cluster is unlikely to be able to fulfil the original storage service.
size
Size modifications are processed in a variety of ways depending on the type of application. For NAS applications, volumes are grown or new volumes are added. For SAN applications, LUNs are grown, new LUNs are added to existing volumes, or new LUNs are added to new volumes. If new storage elements are created, they can be found using the GET /application/applications/{application.uuid}/components interface. The creation time of each storage object is included, and the newly created objects will use the same naming scheme as the previous objects. Resize follows the best practices associated with the type of application being expanded. Reducing the size of an application is not supported.
igroup_name
Modification of the igroup name allows an entire application to be mapped from one initiator group to another. Data access will be interrupted as the LUNs are unmapped from the original igroup and remapped to the new one.
Application state
During a modification, the state property of the application updates to indicate modifying. In modifying state, statistics are not available and snapshot operations are not allowed. If the modification fails, it is possible for the application to be left in an inconsistent state, with the underlying ONTAP storage elements not matching across a component. When this occurs, the application is left in the modifying state until the command is either retried and succeeds or a call to restore the original state is successful.
  1. Change the storage service of the database of the Oracle application to extreme and resize the redo logs to 100GB.
     "oracle_on_nfs": {
       "db": {
         "storage_service": {
           "name": "extreme"
       "redo_log": {
         "size": "100GB"
  2. Change the storage service, size, and igroup of a generic application by component name.
     "san": {
       "application_components": [
           "name": "component1",
             "name": "value"
           "name": "component2",
           "size": "200GB"
           "name": "component3",
           "igroup_name": "igroup5"
uuid
string
path
True
Application UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
_links
_links
creation_timestamp
string
The time when the application was created.
generation
integer
The generation number of the application. This indicates which features are supported on the application. For example, generation 1 applications do not support Snapshot copies. Support for Snapshot copies was added at generation 2. Any future generation numbers and their feature set will be documented.
mongo_db_on_san
mongo_db_on_san
MongoDB using SAN.
nas
nas
A generic NAS application.
nvme
zapp_nvme
An NVME application.
oracle_on_nfs
oracle_on_nfs
Oracle using NFS.
oracle_on_san
oracle_on_san
Oracle using SAN.
oracle_rac_on_nfs
oracle_rac_on_nfs
Oracle RAC using NFS.
oracle_rac_on_san
oracle_rac_on_san
Oracle RAC using SAN.
protection_granularity
string
Protection granularity determines the scope of Snapshot copy operations for the application. Possible values are "application" and "component". If the value is "application", Snapshot copy operations are performed on the entire application. If the value is "component", Snapshot copy operations are performed separately on the application components.
rpo
rpo
s3_bucket
zapp_s3_bucket
A generic S3 bucket application.
san
san
A generic SAN application.
sql_on_san
sql_on_san
Microsoft SQL using SAN.
sql_on_smb
sql_on_smb
Microsoft SQL using SMB.
state
string
The state of the application. For full functionality, applications must be in the online state. Other states indicate that the application is in a transient state and not all operations are supported.
statistics
statistics
template
template
uuid
string
Application UUID. This field is generated when the application is created.
vdi_on_nas
vdi_on_nas
A VDI application using NAS.
vdi_on_san
vdi_on_san
A VDI application using SAN.
vsi_on_nas
vsi_on_nas
A VSI application using NAS.
vsi_on_san
vsi_on_san
A VSI application using SAN.
Status: 200, Ok
job
job_link
  "job": {
    "uuid": "string"
Status: 202, Accepted
Status: Default, Error
string
storage_service
name
string
The storage service of the database.
dataset
size
integer
The size of the database. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
igroups
name
string
The name of an igroup to nest within a parent igroup. Mutually exclusive with initiators and initiator_objects.
uuid
string
The UUID of an igroup to nest within a parent igroup Usage: <UUID>
initiator_objects
comment
string
A comment available for use by the administrator.
name
string
The WWPN, IQN, or Alias of the initiator. Mutually exclusive with nested igroups and the initiators array.
mongo_db_on_san_new_igroups
The list of initiator groups to create.
comment
string
igroups
array[igroups]
initiator_objects
array[initiator_objects]
initiators
array[string]
name
string
The name of the new initiator group.
os_type
string
The name of the host OS accessing the application. The default value is the host OS that is running the application.
protocol
string
The protocol of the new initiator group.
protection_type
local_rpo
string
The local RPO of the application.
secondary_igroups
name
string
The name of the initiator group for each secondary.
mongo_db_on_san
MongoDB using SAN.
dataset
dataset
new_igroups
array[mongo_db_on_san_new_igroups]
primary_igroup_name
string
The initiator group for the primary.
protection_type
protection_type
secondary_igroups
array[secondary_igroups]
export_policy
component
svm
origin
flexcache
policy
qos
retention
snaplock
storage_service
name
string
The storage service of the application component.
object_stores
nas_application_components_tiering
application-components.tiering
name
string
The name of the application component.
storage_service
storage_service
tiering
total_size
integer
The total size of the application component, split across the member shares. Usage: {<integer>[KB|MB|GB|TB|PB]}
app_cifs_access
The list of CIFS access controls. You must provide either 'user_or_group' or 'access' to enable CIFS access.
exclude_aggregates
app_nfs_access
The list of NFS access controls. You must provide either 'host' or 'access' to enable NFS access.
nas
array[application_components]
protection_type
protection_type
performance
storage_service
storage_service
dh_hmac_chap
controller_secret_key
string
Authentication Controller Secret.
group_size
string
Authentication Diffie-Hellman Group.
hash_function
string
Authentication Hash Function.
host_secret_key
string
Authentication Host Secret.
hosts
dh_hmac_chap
dh_hmac_chap
nqn
string
The host NQN.
priority
string
Host Priority.
zapp_nvme_components_subsystem
components.subsystem
hosts
array[hosts]
name
string
The name of the subsystem accessing the component. If neither the name nor the UUID is provided, the name defaults to <application-name>_<component-name>, whether that subsystem already exists or not.
os_type
string
The name of the host OS accessing the component. The default value is the host OS that is running the application.
uuid
string
The UUID of an existing subsystem to be granted access to the component.
zapp_nvme_components_tiering
components
name
string
namespace_count
integer
The number of namespaces supported per request, with a total limit of 1024 per volume.
os_type
string
The name of the host OS running the application.
performance
performance
subsystem
tiering
total_size
integer
The total size of the component, spread across member namespaces. Usage: {<integer>[KB|MB|GB|TB|PB]}
local
name
string
remote
rpo
local
local
zapp_nvme
components
array[components]
rpo
rpo
storage_service
name
string
The storage service of the archive log.
archive_log
size
integer
The size of the archive log. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
db
size
integer
storage_service
storage_service
storage_service
name
string
The storage service of the ORACLE_HOME storage volume.
ora_home
size
integer
The size of the ORACLE_HOME storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
storage_service
name
string
The storage service of the redo log group.
redo_log
size
integer
The size of the redo log group. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
oracle_on_nfs
Oracle using NFS.
archive_log
archive_log
db
db
ora_home
ora_home
protection_type
protection_type
redo_log
redo_log
oracle_on_san_new_igroups
comment
string
igroups
array[igroups]
initiator_objects
initiators
array[string]
name
string
os_type
string
protocol
string
oracle_on_san
Oracle using SAN.
archive_log
archive_log
db
db
igroup_name
string
The name of the initiator group through which the contents of this application will be accessed. Modification of this parameter is a disruptive operation. All LUNs in the application component will be unmapped from the current igroup and re-mapped to the new igroup.
new_igroups
array[oracle_on_san_new_igroups]
ora_home
ora_home
protection_type
protection_type
redo_log
redo_log
storage_service
name
string
The storage service of the Oracle grid binary storage volume.
grid_binary
size
integer
The size of the Oracle grid binary storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
storage_service
name
string
The storage service of the Oracle CRS volume.
oracle_crs
storage_service
storage_service
oracle_rac_on_nfs
archive_log
archive_log
db
db
grid_binary
grid_binary
ora_home
ora_home
oracle_crs
oracle_crs
protection_type
protection_type
redo_log
redo_log
db_sids
igroup_name
string
oracle_rac_on_san_new_igroups
comment
string
igroups
array[igroups]
initiator_objects
initiators
array[string]
name
string
os_type
string
protocol
string
oracle_rac_on_san
archive_log
archive_log
db
db
db_sids
array[db_sids]
grid_binary
grid_binary
new_igroups
array[oracle_rac_on_san_new_igroups]
ora_home
ora_home
oracle_crs
oracle_crs
protection_type
protection_type
redo_log
redo_log
local
description
string
A detailed description of the local RPO. This will include details about the Snapshot copy schedule.
name
string
The local RPO of the component. This indicates how often component Snapshot copies are automatically created.
remote
description
string
A detailed description of the remote RPO.
name
string
The remote RPO of the component. A remote RPO of zero indicates that the component is synchronously replicated to another cluster.
rpo
local
local
remote
remote
components
name
string
Component Name.
rpo
rpo
uuid
string
Component UUID.
local
description
string
name
string
The local RPO of the application. This indicates how often application Snapshot copies are automatically created.
remote
description
string
name
string
The remote RPO of the application. A remote RPO of zero indicates that the application is synchronously replicated to another cluster.
rpo
components
array[components]
is_supported
boolean
Is RPO supported for this application? Generation 1 applications did not support Snapshot copies or MetroCluster.
local
local
remote
remote
zapp_s3_bucket_application_components_access_policies_conditions
conditions
delimiters
array[string]
max_keys
array[integer]
prefixes
array[string]
source_ips
array[string]
usernames
array[string]
The list of S3 objectstore policies to be created.
actions
array[string]
principals
array[string]
resources
array[string]
snapshot_policy
The list of application components to be created.
name
string
size
integer
The total size of the S3 Bucket, split across the member components. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
uuid
string
Object Store Server Bucket UUID Usage: <UUID>
zapp_s3_bucket
array[zapp_s3_bucket_application_components]
san_application_components_tiering
igroup_name
string
lun_count
integer
The number of LUNs in the application component.
name
string
os_type
string
storage_service
storage_service
tiering
total_size
integer
The total size of the application component, split across the member LUNs. Usage: {<integer>[KB|MB|GB|TB|PB]}
san_new_igroups
comment
string
igroups
array[igroups]
initiator_objects
initiators
array[string]
name
string
os_type
string
protocol
string
san
new_igroups
array[san_new_igroups]
protection_type
protection_type
storage_service
name
string
The storage service of the DB.
db
size
integer
The size of the DB. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
storage_service
name
string
The storage service of the log DB.
log
size
integer
The size of the log DB. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
sql_on_san_new_igroups
comment
string
igroups
array[igroups]
initiator_objects
initiators
array[string]
name
string
os_type
string
protocol
string
storage_service
name
string
The storage service of the temp DB.
temp_db
size
integer
The size of the temp DB. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
sql_on_san
db
db
igroup_name
string
log
log
new_igroups
array[sql_on_san_new_igroups]
protection_type
protection_type
temp_db
temp_db
access
sql_on_smb
db
db
log
log
protection_type
protection_type
temp_db
temp_db
iops
per_tb
integer
The number of IOPS per terabyte of logical space currently being used by the application component.
total
integer
The total number of IOPS being used by the application component.
latency
average
integer
The cumulative average response time in microseconds for this component.
raw
integer
The cumulative response time in microseconds for this component.
snapshot
reserve
integer
The amount of space reserved by the system for Snapshot copies.
used
integer
The amount of spacing currently in use by the system to store Snapshot copies.
space
available
integer
The available amount of space left in the application component. Note that this field has limited meaning for SAN applications. Space may be considered used from ONTAP's perspective while the host filesystem still considers it available.
  • readOnly: 1
  • Introduced in: 9.6
  • x-nullable: true
logical_used
integer
The amount of space that would currently be used if no space saving features were enabled. For example, if compression were the only space saving feature enabled, this field would represent the uncompressed amount of space used.
provisioned
integer
The originally requested amount of space that was provisioned for the application component.
reserved_unused
integer
The amount of space reserved for system features such as Snapshot copies that has not yet been used.
savings
integer
The amount of space saved by all enabled space saving features.
used
integer
The amount of space that is currently being used by the application component. Note that this includes any space reserved by the system for features such as Snapshot copies.
used_excluding_reserves
integer
The amount of space that is currently being used, excluding any space that is reserved by the system for features such as Snapshot copies.
used_percent
integer
The percentage of the originally provisioned space that is currently being used by the application component.
storage_service
name
string
The storage service name. AFF systems support the extreme storage service. All other systems only support value.
uuid
string
The storage service UUID.
components
iops
iops
latency
latency
name
string
Component Name.
shared_storage_pool
boolean
An application component is considered to use a shared storage pool if storage elements for for other components reside on the same aggregate as storage elements for this component.
snapshot
snapshot
space
space
statistics_incomplete
boolean
If not all storage elements of the application component are currently available, the returned statistics might only include data from those elements that were available.
storage_service
storage_service
uuid
string
Component UUID.
iops
per_tb
integer
The number of IOPS per terabyte of logical space currently being used by the application.
total
integer
The total number of IOPS being used by the application.
latency
average
integer
The cumulative average response time in microseconds for this application.
raw
integer
The cumulative response time in microseconds for this application.
space
available
integer
The available amount of space left in the application. Note that this field has limited meaning for SAN applications. Space may be considered used from ONTAP's perspective while the host filesystem still considers it available.
  • readOnly: 1
  • x-nullable: true
logical_used
integer
provisioned
integer
The originally requested amount of space that was provisioned for the application.
reserved_unused
integer
savings
integer
used
integer
The amount of space that is currently being used by the application. Note that this includes any space reserved by the system for features such as Snapshot copies.
integer
used_percent
integer
The percentage of the originally provisioned space that is currently being used by the application.
statistics
components
array[components]
iops
iops
latency
latency
shared_storage_pool
boolean
An application is considered to use a shared storage pool if storage elements for multiple components reside on the same aggregate.
snapshot
snapshot
space
space
boolean
If not all storage elements of the application are currently available, the returned statistics might only include data from those elements that were available.
template
protocol
string
The protocol access of the template that was used to provision this application.
version
integer
The version of the template that was used to provision this application. The template version changes only if the layout of the application changes over time. For example, redo logs in Oracle RAC templates were updated and provisioned differently in DATA ONTAP 9.3.0 compared to prior releases, so the version number was increased. If layouts change in the future, the changes will be documented along with the corresponding version numbers.
  • readOnly: 1
  • x-nullable: true
storage_service
name
string
The storage service of the desktops.
desktops
count
integer
The number of desktops to support.
storage_service
storage_service
hyper_v_access
vdi_on_nas
desktops
desktops
protection_type
protection_type
vdi_on_san_new_igroups
comment
string
igroups
array[igroups]
initiator_objects
initiators
array[string]
name
string
protocol
string
vdi_on_san
desktops
desktops
igroup_name
string
new_igroups
array[vdi_on_san_new_igroups]
protection_type
protection_type
storage_service
name
string
The storage service of the datastore.
datastore
count
integer
The number of datastores to support.
storage_service
storage_service
vsi_on_nas
datastore
datastore
protection_type
protection_type
vsi_on_san_new_igroups
comment
string
igroups
array[igroups]
initiator_objects
initiators
array[string]
name
string
protocol
string
vsi_on_san
datastore
datastore
igroup_name
string
new_igroups
array[vsi_on_san_new_igroups]
protection_type
protection_type
application
Applications
_links
_links
creation_timestamp
string
generation
integer
mongo_db_on_san
mongo_db_on_san
MongoDB using SAN.
nas
nas
nvme
zapp_nvme
oracle_on_nfs
oracle_on_nfs
Oracle using NFS.
oracle_on_san
oracle_on_san
Oracle using SAN.
oracle_rac_on_nfs
oracle_rac_on_nfs
oracle_rac_on_san
oracle_rac_on_san
string
rpo
rpo
s3_bucket
zapp_s3_bucket
san
san
sql_on_san
sql_on_san
sql_on_smb
sql_on_smb
state
string
statistics
statistics
template
template
uuid
string
vdi_on_nas
vdi_on_nas
vdi_on_san
vdi_on_san
vsi_on_nas
vsi_on_nas
vsi_on_san
vsi_on_san
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
