REST API reference
Update proxy server, port, username, and password parameters
Updates the proxy server, port, username, and password parameters to configure the network settings for secure communication. This operation ensures that the specified server and port are correctly set up and reachable for proxy services.
HTTP method and endpoint
PATCH /network/http-proxy/{uuid}
Introduced in
ONTAP 9.7
Usage notes
Important notes:
  • IPv6 must be enabled if IPv6 family addresses are specified in the "server" field.
  • The server and the port combination specified using the "server" and "port" fields is validated during this operation. The validation will fail in the following scenarios:
    • The HTTP proxy service is not configured on the server.
    • The HTTP proxy service is not running on the specified port.
    • The server is unreachable.
  • vserver http-proxy modify
uuid
string
path
True
HTTP proxy UUID
Request Body
Name Type Description
authentication_enabled
boolean
Specifies whether or not authentication with the HTTP proxy server is enabled.
password
string
Password to authenticate with the HTTP proxy server when authentication_enabled is set to "true".
port
integer
The port number on which the HTTP proxy service is configured on the proxy server.
scope
string
Set to “svm” for HTTP proxy owned by an SVM. Otherwise, set to "cluster".
server
string
Fully qualified domain name (FQDN) or IP address of the HTTP proxy server.
username
string
Username to authenticate with the HTTP proxy server when authentication_enabled is set to "true".
uuid
string
The UUID that uniquely identifies the HTTP proxy.
Example request
  "password": "string",
  "port": "3128",
  "scope": "string",
  "server": "string",
  "username": "string",
  "uuid": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
26214473
The HTTP proxy configuration is not valid.
23724130
Cannot use an IPv6 name server address because there are no IPv6 interfaces.
26214481
Username and password cannot be empty when HTTP proxy authentication is enabled.
26214482
Username and password cannot be specified when HTTP proxy authentication is disabled.
string
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input.
name
string
IPspace name
uuid
string
IPspace UUID
svm
name
string
The name of the SVM.
uuid
string
network_http_proxy
boolean
password
string
port
integer
scope
string
server
string
username
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
