Update proxy server, port, username, and password parameters
Updates the proxy server, port, username, and password parameters to configure the network settings for secure communication. This operation ensures that the specified server and port are correctly set up and reachable for proxy services.
HTTP method and endpoint
PATCH /network/http-proxy/{uuid}
Introduced in
ONTAP 9.7
Usage notes
Important notes:
IPv6 must be enabled if IPv6 family addresses are specified in the "server" field.
The server and the port combination specified using the "server" and "port" fields is validated during this operation. The validation will fail in the following scenarios:
The HTTP proxy service is not configured on the server.
The HTTP proxy service is not running on the specified port.
The server is unreachable.
Related ONTAP commands
vserver http-proxy modify
uuid |
string |
path |
True |
HTTP proxy UUID |
Request Body
| Name | Type | Description |
authentication_enabled |
boolean |
Specifies whether or not authentication with the HTTP proxy server is enabled. |
password |
string |
Password to authenticate with the HTTP proxy server when authentication_enabled is set to "true". |
port |
integer |
The port number on which the HTTP proxy service is configured on the proxy server. |
scope |
string |
Set to “svm” for HTTP proxy owned by an SVM. Otherwise, set to "cluster". |
server |
string |
Fully qualified domain name (FQDN) or IP address of the HTTP proxy server. |
username |
string |
Username to authenticate with the HTTP proxy server when authentication_enabled is set to "true". |
uuid |
string |
The UUID that uniquely identifies the HTTP proxy. |
Example request
"password": "string",
"port": 3128,
"scope": "string",
"server": "string",
"username": "string",
"uuid": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
26214473 |
The HTTP proxy configuration is not valid. |
23724130 |
Cannot use an IPv6 name server address because there are no IPv6 interfaces. |
26214481 |
Username and password cannot be empty when HTTP proxy authentication is enabled. |
26214482 |
Username and password cannot be specified when HTTP proxy authentication is disabled. |
href |
string |
_links
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input. This is mutually exclusive with SVM during POST and PATCH.
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
svm
This is mutually exclusive with IPspace during POST and PATCH.
name |
string |
uuid |
string |
network_http_proxy
boolean |
password |
string |
port |
integer |
scope |
string |
server |
string |
username |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
