Update proxy server, port, username, and password parameters
PATCH /network/http-proxy/{uuid}
Updates the proxy server, port, username, and password parameters. Important notes:
IPv6 must be enabled if IPv6 family addresses are specified in the "server" field.
The server and the port combination specified using the "server" and "port" fields is validated during this operation. The validation will fail in the following scenarios:
The HTTP proxy service is not configured on the server.
The HTTP proxy service is not running on the specified port.
The server is unreachable.
Related ONTAP commands
vserver http-proxy modify
Learn more
uuid |
string |
path |
True |
HTTP proxy UUID |
Request Body
| Name | Type | Description |
_links |
port |
integer |
The port number on which the HTTP proxy service is configured on the proxy server. |
scope |
string |
Set to “svm” for proxy owned by an SVM. Otherwise, set to "cluster". |
server |
string |
The fully qualified domain name (FQDN) or IP address of the proxy server. |
uuid |
string |
The UUID that uniquely identifies the HTTP proxy. |
Example request
"href": "/api/resourcelink"
"port": 3128,
"scope": "string",
"server": "string",
"uuid": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
26214473 |
The HTTP proxy configuration is not valid. |
23724130 |
Cannot use an IPv6 name server address because there are no IPv6 interfaces. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input.
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
network_http_proxy
_links |
port |
integer |
scope |
string |
server |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
