REST API reference
Update the AKV configuration
Updates the AKV configuration, adjusting settings specific to Azure NetApp Files Cloud Volume Services. This allows you to modify authentication and connection parameters for enhanced integration with Azure Key Vault.
HTTP method and endpoint
PATCH /security/azure-key-vaults/{uuid}
Introduced in
ONTAP 9.8
Usage notes
Note: This method is only available to the Azure NetApp Files Cloud Volume Services.
Optional properties
  • client_secret - New password used to prove the application's identity to the AKV.
  • key_id- Key Identifier of the new AKV key encryption key.
  • proxy_type` - Type of proxy (http, https etc.) if proxy configuration is used.
  • proxy_host - Proxy hostname if proxy configuration is used.
  • proxy_port - Proxy port number if proxy configuration is used.
  • proxy_username - Proxy username if proxy configuration is used.
  • proxy_password - Proxy password if proxy configuration is used.
  • client_id - Application (client) ID of the deployed Azure application with appropriate access to an AKV.
  • tenant_id - Directory (tenant) ID of the deployed Azure application with appropriate access to an AKV.
  • security key-manager external azure update-client-secret
  • security key-manager external azure rekey-external
  • security key-manager external azure update-config
uuid
string
path
True
AKV UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
client_id
string
Application client ID of the deployed Azure application with appropriate access to an AKV.
client_secret
string
Password used by the application to prove its identity to AKV.
ekmip_reachability
array[ekmip_reachability]
key_id
string
Key Identifier of AKV key encryption key.
proxy_host
string
Proxy host.
proxy_password
string
Proxy password. Password is not audited.
proxy_port
integer
Proxy port.
proxy_type
string
Type of proxy.
proxy_username
string
Proxy username.
svm
svm
tenant_id
string
uuid
string
A unique identifier for the Azure Key Vault (AKV).
Example request
  "client_id": "aaaaaaaa-bbbb-aaaa-bbbb-aaaaaaaaaaaa",
  "client_secret": "abcdef",
  "ekmip_reachability": [
      "code": "346758",
      "message": "embedded KMIP server status unavailable on node.",
      "node": {
        "name": "node1",
  "key_id": "https://keyvault1.vault.azure.net/keys/key1",
  "proxy_host": "proxy.eng.com",
  "proxy_password": "proxypassword",
  "proxy_port": "1234",
  "proxy_type": "http",
  "proxy_username": "proxyuser",
  "svm": {
    "name": "svm1",
  "tenant_id": "zzzzzzzz-yyyy-zzzz-yyyy-zzzzzzzzzzzz",
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
65537120
Azure Key Vault is not configured for the given SVM.
65537504
Internal error. Failed to store configuration in internal database.
65537517
The field "client_secret" must be specified.
65537541
No inputs were provided for the patch request.
65537547
One or more volume encryption keys for encrypted volumes of this data SVM are stored in the key manager configured for the admin SVM. Use the REST API POST method to migrate this data SVM's keys from the admin SVM's key manager to this data SVM's key manager before running the rekey operation.
string
azure_reachability
Indicates whether or not the AKV service is reachable from all the nodes in the cluster. This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code
integer
Code corresponding to the status message. Returns a 0 if AKV service is reachable from all nodes in the cluster.
message
string
Error message set when reachability is false.
reachable
boolean
Set to true when the AKV service is reachable from all nodes of the cluster.
node
name
string
uuid
string
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster. This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code
integer
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster.
message
string
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false.
node
node
reachable
boolean
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster.
state
Indicates whether or not the AKV wrapped internal key is available cluster wide. This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
available
boolean
Set to true when an AKV wrapped internal key is present on all nodes of the cluster.
code
integer
Code corresponding to the status message. Returns a 0 if AKV wrapped key is available on all nodes in the cluster.
message
string
Error message set when top-level internal key protection key (KEK) availability on cluster is false.
svm
name
string
The name of the SVM.
uuid
string
azure_key_vault
client_id
string
client_secret
string
ekmip_reachability
key_id
string
proxy_host
string
Proxy host.
proxy_password
string
proxy_port
integer
Proxy port.
proxy_type
string
Type of proxy.
proxy_username
string
Proxy username.
svm
svm
tenant_id
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
