REST API reference
Update the AKV configuration
Updates the Azure Key Vault (AKV) configuration to modify the existing setup and credentials. This is useful when making changes to authentication methods or proxy settings in your AKV environment.
HTTP method and endpoint
PATCH /security/azure-key-vaults/{uuid}
Introduced in
ONTAP 9.8
Usage notes
Updates the AKV configuration.
Optional properties
  • client_secret or client_certificate - New secret or new PKCS12 certificate used to prove the application's identity to the AKV.
  • proxy_type - Type of proxy (http, https etc.) if proxy configuration is used.
  • proxy_host - Proxy hostname if proxy configuration is used.
  • proxy_port - Proxy port number if proxy configuration is used.
  • port - Authorization server and vault port number.
  • oauth_host - Open authorization server host name.
  • vault_host - AKV host subdomain.
  • verify_host - Verify the identity of the AKV host name.
  • `verify_ip ` - Verify the identity of the AKV IP address.
  • proxy_username - Proxy username if proxy configuration is used.
  • proxy_password - Proxy password if proxy configuration is used.
  • client_id - Application (client) ID of the deployed Azure application with appropriate access to an AKV.
  • tenant_id - Directory (tenant) ID of the deployed Azure application with appropriate access to an AKV.
  • skip_verification - Skip the verification of the updated credentials, set to true to bypass the verification. The default value is false.
  • security key-manager external azure update-client-secret
  • security key-manager external azure update-credentials
  • security key-manager external azure update-config
uuid
string
path
True
AKV UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
_links
_links
authentication_method
string
Authentication method for the AKV instance.
azure_reachability
azure_reachability
Indicates whether or not the AKV service is reachable from all the nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
client_certificate
string
PKCS12 Certificate used by the application to prove its identity to AKV.
client_id
string
Application client ID of the deployed Azure application with appropriate access to an AKV.
client_secret
string
Secret used by the application to prove its identity to AKV.
ekmip_reachability
array[ekmip_reachability]
enabled
boolean
Indicates whether the configuration is enabled.
oauth_host
string
port
integer
proxy_host
string
Proxy host.
proxy_password
string
Proxy password. Password is not audited.
proxy_port
integer
Proxy port.
proxy_type
string
Type of proxy.
proxy_username
string
Proxy username.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
skip_verification
boolean
Set to true to skip the verification of the updated user credentials when updating credentials. The default value is false.
state
state
Indicates whether or not the AKV wrapped internal key is available cluster wide. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
tenant_id
string
uuid
string
A unique identifier for the Azure Key Vault (AKV).
vault_host
string
AKV host subdomain.
verify_host
boolean
verify_ip
boolean
Example request
  "authentication_method": "client_secret",
  "azure_reachability": {
    "code": "346758",
    "message": "AKV service is not reachable from all nodes - reason."
  "client_certificate": "<CERTIFICATE-CONTENT>",
  "client_id": "aaaaaaaa-bbbb-aaaa-bbbb-aaaaaaaaaaaa",
  "client_secret": "abcdef",
  "ekmip_reachability": [
      "code": "346758",
      "message": "embedded KMIP server status unavailable on node.",
      "node": {
        "name": "node1",
  "oauth_host": "login.microsoftonline.com",
  "port": 443,
  "proxy_host": "proxy.eng.com",
  "proxy_password": "proxypassword",
  "proxy_port": 1234,
  "proxy_type": "http",
  "proxy_username": "proxyuser",
  "scope": "string",
  "skip_verification": "",
  "state": {
    "code": "346758",
    "message": "Top-level internal key protection key (KEK) is unavailable on the following nodes with the associated reasons: Node: node1. Reason: No volumes created yet for the SVM. Wrapped KEK status will be available after creating encrypted volumes."
  "tenant_id": "zzzzzzzz-yyyy-zzzz-yyyy-zzzzzzzzzzzz",
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "vault_host": "vault.azure.net",
  "verify_host": "",
  "verify_ip": ""
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
65537120
Azure Key Vault is not configured for the given SVM.
65537504
Internal error. Failed to store configuration in internal database.
65537517
The field "client_secret" must be specified.
65537540
Invalid client secret.
65537541
No inputs were provided for the patch request.
65537547
One or more volume encryption keys for encrypted volumes of this data SVM are stored in the key manager configured for the admin SVM. Use the REST API POST method to migrate this data SVM's keys from the admin SVM's key manager to this data SVM's key manager before running the rekey operation.
65537573
Invalid client certificate.
string
azure_reachability
code
string
Code corresponding to the status message. Returns a 0 if AKV service is reachable from all nodes in the cluster.
message
string
Error message set when reachability is false.
reachable
boolean
Set to true when the AKV service is reachable from all nodes of the cluster.
configuration
Security keystore object reference.
name
string
Name of the configuration.
uuid
string
Keystore UUID.
node
name
string
uuid
string
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code
string
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster.
message
string
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false.
node
node
reachable
boolean
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster.
state
available
boolean
Set to true when an AKV wrapped internal key is present on all nodes of the cluster.
code
string
Code corresponding to the status message. Returns a 0 if AKV wrapped key is available on all nodes in the cluster.
message
string
Error message set when top-level internal key protection key (KEK) availability on cluster is false.
svm
name
string
uuid
string
azure_key_vault
_links
_links
string
azure_reachability
azure_reachability
client_certificate
string
client_id
string
client_secret
string
ekmip_reachability
enabled
boolean
oauth_host
string
port
integer
proxy_host
string
Proxy host.
proxy_password
string
proxy_port
integer
Proxy port.
proxy_type
string
Type of proxy.
proxy_username
string
Proxy username.
scope
string
skip_verification
boolean
state
state
tenant_id
string
uuid
string
vault_host
string
AKV host subdomain.
verify_host
boolean
verify_ip
boolean
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
