REST API reference
Update SnapLock audit logs
Updates the SnapLock audit log configuration, including modifying the volume, adjusting its attributes, or archiving current log files as needed.
HTTP method and endpoint
PATCH /storage/snaplock/audit-logs/{svm.uuid}
Introduced in
ONTAP 9.7
Usage notes
Updates one of the following:
  • the audit log volume,
  • the attributes of the audit log volume present, or
  • archive the current audit log files
  • snaplock log modify
svm.uuid
string
path
True
SVM UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
log_archive
log_archive
log_volume
snaplock_log_volume
Example request
  "log_archive": {
    "base_name": "string",
    "expiry_time": "2058-06-04T19:00:00Z",
    "path": "/snaplock_log/system_logs/20180822_005947_GMT-present",
    "size": "20000"
  "log_volume": {
    "max_log_size": "20971520",
    "retention_period": "P30M",
    "volume": {
      "name": "volume1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response codes
Error code Description
14090344
If log_volume is specified, then log_archive must not be specified
14090345
If log_archive.base_name is specified, then log_archive.archive must also be specified
14090346
Internal Error. Wait a few minutes, then try the command again
string
log_archive
archive
boolean
Archive the specified SnapLock log file for the given base_name, and create a new log file. If base_name is not mentioned, archive all log files.
base_name
string
Base name of log file
expiry_time
string
Expiry time of the log file in date-time format. Value '9999-12-31T00:00:00Z' indicates infinite expiry time.
path
string
Absolute path of the log file in the volume
size
integer
Size of the log file in bytes
snaplock_log_file
archive
boolean
base_name
string
expiry_time
string
path
string
size
integer
volume
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
snaplock_log_volume
max_log_size
integer
Maximum size of log file in bytes
retention_period
string
Specifies the default log record retention period. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, minutes and seconds. A period specified for years, months and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively. For example "P10Y" represents a duration of 10 years. A duration in hours, minutes and seconds is represented by "PTH", "PTM", and "PTS" respectively. The period string must contain only a single time element i.e. either years, months, days, hours, minutes or seconds. A duration which combines different periods is not supported, example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the retention period field also accepts the string "infinite".
volume
volume
svm
name
string
The name of the SVM.
uuid
string
snaplock_log
log_archive
log_archive
log_volume
snaplock_log_volume
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
